Build Time!
Old Mar 10, 2017 | 01:30 PM
  #151
knottyrope's Avatar
knottyrope
those bonded sealing washers made of rubber or Viton?
Old Mar 10, 2017 | 01:57 PM
  #152
dclack's Avatar
dclack
Originally Posted by Bonanza35
International makes a kit to do this, I think it's $50.oo. I just did mine, it's a 99 SD, but just changed the o-ring and used motorcraft pan sealant on the out side under the nut and up on the treads, so far so good. Mitt be different on the 97 and eariler trucks. I didn't use the international kit. Have friends that did and never had a problem. I wasn't pulling the motor for this, and the finished product looks great.
Got a link? I've never seen the International kit to do this. The only one I've seen is a replacement stock adapter which requires pulling the engine to get the pan out.
Not sure. Probably just rubber so we will see how well they hold up. If these don't last I'll probably try some copper washers; I'm just not sure how smooth of a surface I can get for them to seal.
Old Mar 10, 2017 | 08:49 PM
  #153
dclack's Avatar
dclack
I went and grabbed another bonded washer and am currently soaking it in oil. We'll see what happens in a day or two. I also found some fiber washers that might use instead. Then I finished the backing plate and test fitted it with a short piece of tubing and the dipstick. Slides right in no problem.
Old Mar 10, 2017 | 09:16 PM
  #154
z31freakify's Avatar
z31freakify
Fingers crossed, looks like the $300 piece but without the O rings. If it works I'm first in the list when you start making them lol....
Old Mar 11, 2017 | 10:49 AM
  #155
dclack's Avatar
dclack
Everything looks better with a little paint. These are the fiber washers I found; I think I'm going to start with them. Yesterday I was watching Youtube on how to grind a regular drill bit to cut a flat bottom hole. I think a small recess with these fiber washers would be the ticket.
Old Mar 11, 2017 | 11:03 AM
  #156
z31freakify
On one of the screws put a dab of weld. So it can't come unloose when you try to put in.
Old Mar 11, 2017 | 11:10 AM
  #157
dclack's Avatar
dclack
Yep, that's the plan. I've already test fitted it on a piece of sheet metal. Slides right in fine.
Old Mar 11, 2017 | 08:06 PM
  #158
ReBilld's Avatar
ReBilld
Looks good Darin! Great job!
Old Mar 12, 2017 | 12:07 PM
  #159
dclack's Avatar
dclack
Thanks Bill! Last night I noticed a potential design flaw: with the backing plate being flat it could bottom out on the small diameter of the adapter and not the inside of the pan. I think I would have been ok because of the thickness of the gasket on the outside, but better to be safe than sorry, right? So I welded some 'tabs' to the ends of the backing plate to ensure it hits the pan only. Hopefully I will be able to install it this afternoon.
Old Mar 12, 2017 | 01:44 PM
  #160
BBslider001's Avatar
BBslider001
Dang dude....that's some talent!!
Old Mar 12, 2017 | 02:30 PM
  #161
Bonanza35's Avatar
Bonanza35
The International repair kit number is 1846146C91. Look on the 1999-203 site for the repair. Andy did the repair back in 2077 on his 1999. I talked to him and it is still holding. I'm not good on these things so posting a web site I can't do. Mine is still holding the way I did it also.
Old Mar 12, 2017 | 09:26 PM
  #162
dclack's Avatar
dclack
I did some searching on that International kit and it looks like it's the reseal kit for the stock adapter which I've already tried. But as you'll see below, the stock adapter gets bent and the o-ring has a hard time sealing.
There's that leaky POS!
Here's where you can see the adapter inside is bent.
The point of no return! Pan cleaned up and ready for the new adapter.
And there she is!
I used a little black rtv on both sides of the gasket and since there is plenty of dipstick tube below the o-ring crimps, I went ahead and put it back in without cutting it. If all is well in a few days, I'll cut the tube to length. In the meantime I scratched a new 'full' mark on the dipstick to compensate for the extra length.
Old Mar 12, 2017 | 10:45 PM
  #163
oldbird1965's Avatar
oldbird1965
Very good job Darrin! Where were you when I needed you? lol
Reps sent.
Old Mar 12, 2017 | 11:26 PM
  #164
Bonanza35's Avatar
Bonanza35
The international kit comes with two sealants, RTV-T-442 and 515 lock tight besides the o-rings. And yes you have to clean it up really good. Your repair that leaked didn't show the way they said to do it. But I'm glad you got her done. Real clean looking.
Old Mar 13, 2017 | 09:32 AM
  #165
dclack's Avatar
dclack
This is the repair kit I did back around '09. It doesn't have the RTV, just the 515.
But my main problem is that I needed a new adapter inside. As you can see in this video (~2:10 mark), the stock adapter gets bent and keeps the o-ring from getting a tight seal. So it's time to either pull the engine and pan or get an adapter that bolts from the outside. I also think that most of my leak was from around the dipstick tube itself, which is another reason I wanted to make my own to eliminate that o-ring.
