emergency
Old Nov 8, 2015 | 06:25 PM
  #76
iwsmitty25's Avatar
iwsmitty25
Originally Posted by Ferguson65
Since I didn't see it anywhere, how many miles on this thing?
159547 why
Old Nov 8, 2015 | 06:26 PM
  #77
UGA33's Avatar
UGA33
Originally Posted by iwsmitty25
��...wonder how much of a loan I'll need for that?
It's pretty bad when you have to get a loan to fix your vehicle ��
Probably all they will need to do is plug the IDS up to it to figure the issue out. About $100....
How much the bill is next depends on you.
Old Nov 8, 2015 | 06:28 PM
  #78
iwsmitty25's Avatar
iwsmitty25
Wondering why I should have to pay anything on what is pretty much a new truck
Old Nov 8, 2015 | 06:30 PM
  #79
iwsmitty25's Avatar
iwsmitty25
Originally Posted by senix
I would start with the batteries and fuses.
Apparently you haven't been paying attention ⚠... I said getting fuel and fuses and batteries are good
Old Nov 8, 2015 | 06:34 PM
  #80
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
In rereading this total tread. You state you got fuel 30 miles back. Then truck won't start. I'm wondering even though you have codes. If the fuel filter plugged just enough so it won't fire. Bad fuel does a number on these engines.
  #81
Ferguson65's Avatar
Ferguson65
159547 why
That's why I asked. It's not a new truck, its a likely 5 year old truck with 159K on it. Why do you feel that Ford should owe you a freebie? You bought and used a truck for 159k miles and the warranty was clearly listed as 100k on the engine. Big trucks, big bucks, gotta pay to play. I have nothing else to offer, so I'm out.
Old Nov 8, 2015 | 06:36 PM
  #82
iwsmitty25's Avatar
iwsmitty25
Originally Posted by sgrol
Yeah, that'll fix it. Have been holding back on saying this for a while but I'm doubting the validity of this thread.
You can doubt it all you want...you're not the one stranded and just paid to have trailer towed home and your not the one that has to pay to have the truck towed 350 miles home.
Old Nov 8, 2015 | 06:38 PM
  #83
sgrol's Avatar
sgrol
Troll, I'm out too.
Old Nov 8, 2015 | 06:41 PM
  #84
iwsmitty25's Avatar
iwsmitty25
So clueless...you had nothing to offer in the first place.
If you understood what I've been trying to do the last day and a half and how frustrating it is trying to figure out why a truck could run fine then after you've rested a couple hours and went to leave and the truck wouldn't start all of a sudden and you're a senior citizen on a fixed income..then you could understand
Old Nov 8, 2015 | 06:48 PM
  #85
iwsmitty25's Avatar
iwsmitty25
Thanks for your input.
On the filter on the frame I opened the drain valve and no water came out.
A guy suggested that I pull one of the filters and drain it and fill it with power steering or transmission fluid..don't remember..but said that would clean it out
Old Nov 8, 2015 | 06:51 PM
  #86
bigredtruckmi
Veteran: Navy
Don't do it...... It will damage fuel injection system! It work d on the old diesels that didn't use the high pressure rail system
  #87
senix's Avatar
senix
No! do not put any thing in the filters. My suggestion would be to actually take the lower one off and inspect it and the housing,
Engine one is sealed and you can't do that.
Concern is perhaps bad fuel.
Old Nov 8, 2015 | 06:53 PM
  #88
bigredtruckmi
Veteran: Navy
Yes you didn't get water but I was thinking of the filter picking up grime from fuel. It looks like a white slime on filter. Does not come out of filter. I Had this happen on the road.
  #89
iwsmitty25's Avatar
iwsmitty25
Troll, I'm out too.
See ya!... You had nothing to offer to help so your comments are pretty useless
Old Nov 8, 2015 | 06:59 PM
  #90
iwsmitty25's Avatar
iwsmitty25
Yes you didn't get water but I was thinking of the filter picking up grime from fuel. It looks like a white slime on filter. Does not come out of filter. Had this happen on the road.
Thanks...when I get home and get truck home tomorrow I'll definitely check that out.but since I own a new oil pressure sending unit sensor from auto zone I think I'll replace it since I get message in message center about low oil pressure. It looks like an old oil can
