The "Mule" Build
Installed 2" wheel spacers and it improved the handling with the stock wheels and stock 235 85 16. Removed the front sway bar handles nice even when towing, So far the beast hasn't disappointed me,
14k in just 2 months mostly towing heavy stuff mostly ranging from 12-14k Colorado was the one that put her to the test going up I70 towards the Johnson Tunnel towing 12K iirc.
Overall she's done what I have asked her to do.
Pics or didnt happen right?
I initially bought only 2 then another 2 then I said Fak it and bought the last 4.
97 f150 2wd 4.2
Don't have the before pics but they are somewhere in tbe Morning coffee thread in the SD section.
And the newest and se vende flip
List on this s10 was sorta long but in the end should make good profit.
Mechanically she was 100% but lacked in appearance. List are as follow
1. New fan shroud
2. New AC compressor with lines and condenser
3. New heater core
4. All new coolant hoses and thermostat
5. New windshield
6. New windshield washer bottle with motor.
7. New fan clutch (old one was locked up)
8. Installed used mud flaps
9. New dash cover mat
10. Installed all new LED inside the truck from the cluster to the dome light to the rear view mirror
11. DIY bed liner
12. Complete fluid change including trans engine diff, cooling system and power steering
13. tinted windows
14. Installed new door and window seals
15. DIY upholster not pretty but better than how it looked
16. Painted truck and wheels
17. Cleaned the best I could inside
I wish I could keep this truck but have no use for it.
The dime looks good man
Im sure not mad at a lil truck flipping to supplement the income. Helps on the home fires.
Although it was a work trip it was fun, got to explore and it's incredible over there I really liked it. Truck did great but those big hills got me thinking about changing back to my 4.10 diff and maybe going the T/4 route or one of those KC drop in turbos, the bad part is I couldn't use my tunes either since installing the new trans which has a shift kit and the TW tunes don't make it to happy when shifting.
Next year I'm jumping to the Hydra
Doing Factory Tourmaline Green.
2-3 weeks from now we are going to see how this pig turns out.
