Haven't visited the forum in awhile. Nice to see a dually only section. Great trucks. Our 2012 is stock except for when the turbo failed we upgraded to the 2015 turbo. Runs great.
Pretty rig.........
What have you noticed different with the new turbo.....??
Thanks. I need to check some records but on my one trip on the 15 turbo with a loaded car hauler, mileage was improved. Before going out on a limb, I need to verify the old numbers.
Not sure if the improvement was the turbo, tune or both. Now you have me wondering. I'll do some homework.
You should be able to pull more boost and not have it drop off at elevations?
Is there a Daytime Running Light capability built into the truck that can be "turned on" by the dealer?
Also... anyway to configure the truck so it doesn't run the chime about EVERYTHING?
Lights left on... Ok!
Everything else... key in ign, seatbelts not latched, parking brake on, etc etc I can handle myself. I don't need nanny chiming at me.
I'm not sure about your southern trucks but up here everything comes with daytime run lights.
My 450 also came with the four corner strobe kit, very cool, I run an amber strobe bar on my rear rack anyway but more flashy the better!
Define "up here". If you are saying Canada I am hip. My 2010 Dodge Challenger had a "hidden" DRL feature that was built into the car to meet Canadian laws. One just had to know that fact and then go to the dealer and make them smart on it. Then they just searched around with their programming tool and found the switch and turned them on. I had hoped that would be the case here with the F350.
pics will come a little later, Mine is a 2012.. Rancho 9000xl adjustable shocks, with wireless controller.
Firestone airbags 2535 kit, with Airlift Wireless One controller.
these came off my 2012 F250 SRW, SB. trade for the dually.
Viair 10007 on board air kit. Upfitter 1
recently added an LED light bar to the front, wired to Upfitter 3 and brights.
60 gal RDS toolbox tank, gravity feed, with electric cutoff, wired to Upfitter 2.
Use a B&W Patriot 16k rail based hitch for the FW, as the rails were already installed when I purchased the truck used with 6000 miles, August 2013.
also have a Tuff Tonneau soft roll up bed cover
Locking gas cap, just today added a lock to the fuel door itself.
This is a lariat with sunroof and nav. The hood was open cause I was looking for the pins that hold the cowl to the gasket.. the PO had the shroud wrapped, but they didn't secure it again. dealer didn't have the pins like they said they did!
How do you like the Rancho 9000 XL Shocks? Thinking of putting on mine I haul everyday
Yes, the dealer can turn that function on in the computer. Many have done it.
Shocks:
9000XLs........Fantastic shocks !! I have had them on two trucks now.
Well that is good information....
I don't have anything in any of my menus in the information displays that address DRLs. I will have to talk to my service advisor. When they are recalibrating for the Titan tank they can hit the DRLs as well.
