Duallys Only
Old Apr 30, 2015 | 09:06 AM
  #601
17 Oaks's Avatar
17 Oaks
Originally Posted by Sailor_Roy
Great Flaps................
They are a world of diff between them and most other flaps. Thicker, longer and the inside is grooved to keep water from splashing out.
I put them on in the driveway, did not take off my tires. WHAT a job it was. Had the camper loaded on the truck so to remove the tires I would have had to remove the camper.
Duraflap are a great product, use all stainless steel metal, and it attaches it with bolts and I put Blue LockTite on them. Strongly recommend them...
Old Apr 30, 2015 | 09:15 AM
  #602
Big-Foot's Avatar
Big-Foot
Originally Posted by 17 Oaks
Remember Bandag, which used some kind of cold process, not sure they are still around???
They're still around... If you check, they still use an oven to cure the tire even though the tread is rolled on cold.
The old recaps that people found along the roads years ago were simply a cold tread cap and no vulcanizing / curing process was used on them.
I think that Dave is right in that most of what you see along side the road today are shucked treads from failed tires that were pushed beyond their limits in one way or another.. Or they were poorly designed tires from the get-go like Goodyear Marathons (aka - China Bombs)....
Old Apr 30, 2015 | 09:17 PM
  #603
dualwheels66's Avatar
dualwheels66
So do you think 19.5 recapped tires are worth it on a truck that weighs just over 11,000 lbs. Is it worth it long term and how good are those tires in the snow?
Old Apr 30, 2015 | 10:48 PM
  #604
dlibson's Avatar
dlibson
They are just as good as a new tire for life and wear. You have tons of tread choices, so pick a good one for snow.
Old May 1, 2015 | 06:42 PM
  #605
dixoncity's Avatar
dixoncity
You guys have any more room in the Dually Club? Just purchased Wednesday.
2015 F350 / 2014 AF865
Old May 1, 2015 | 07:12 PM
  #606
senix's Avatar
senix
Very nice. Looks like a nice camper there. Goes with the color of the truck.
Old May 1, 2015 | 09:35 PM
  #607
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Great looking rig Dixon............
Old May 1, 2015 | 10:23 PM
  #608
gwcon's Avatar
gwcon
Nice truck Dixoncity. Congrats and enjoy.
Old May 2, 2015 | 07:15 AM
  #609
Jigger2020's Avatar
Jigger2020
Yup, good lookin truck
Old May 2, 2015 | 10:07 AM
  #610
Desert Don's Avatar
Desert Don
We can always make more room in the wide hips club! Welcome to the addiction! Nice looking rig!
Old May 2, 2015 | 11:17 AM
  #611
dualwheels66
That's a nice looking set up there dixon, what are the specs on the slide in?
Old May 3, 2015 | 08:23 PM
  #612
dixoncity's Avatar
dixoncity
Thanks for all the compliments.
That's a Arctic Fox 865, about 3,000 lbs dry. Don't know much more other specs off had, but it is a great camper. I was hauling her around on my 2011 F350 SRW, but after I went on a CAT scale and found that I was over 1,000 lbs over the GVWR, I figured I go the safe route and upgrade my ride. Haven't taken it on a trip yet, still setting up the truck with tie downs etc.
Old May 4, 2015 | 06:01 PM
  #613
dixoncity's Avatar
dixoncity
Tire Rotation
Hey guys, being a new dually owner, I just learned that the tires can be rotated, but the wheels can not.(please let me know if I'm misinformed) In other words, the tires must be broke down and then remounted for a proper rotation.
The question is what do you guys do? Don't rotate and replace the front tires more frequently than the rears, or pay the expense for the rotation. Based on six tires, I'm thinking a proper rotation would cost at least $125. A quick search of my tires LT245/75R 17 E, run about $150 to about $200 each.
Old May 4, 2015 | 06:08 PM
  #614
senix's Avatar
senix
You rotate side to side. Don't break them down.
All drivers side goes passenger, all passenger to the drivers side.
Old May 4, 2015 | 06:57 PM
  #615
Ferguson65's Avatar
Ferguson65
Yep, that's it there. Though so far in my 11k miles the rears haven't shown any noticeable odd wear so I have left them alone. I did the fronts at 5600 miles and need to do them again........................
