Duallys Only
Old Dec 27, 2019 | 06:56 AM
  #2101
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
We like the blue also but couldn’t locate one so went with second choice
Old Dec 27, 2019 | 10:23 AM
  #2102
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Love that blue!
Old Dec 27, 2019 | 10:34 AM
  #2103
Shiloh51933's Avatar
Shiloh51933
Originally Posted by SuperchargedPSD
This Truck is gorgeous!!
Old Dec 27, 2019 | 11:24 AM
  #2104
water_junky's Avatar
water_junky
Anyone else notice that the cab lights and the front clearance light on the rear fender of the 2020 duallys are a clear lens instead of amber?
Old Dec 27, 2019 | 12:14 PM
  #2105
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Originally Posted by bigredtruckmi
Our new rig
Congratulations!
Congratulations, that's a pretty one!
Old Dec 27, 2019 | 07:42 PM
  #2106
SuperchargedPSD's Avatar
SuperchargedPSD
They do have Amber bulbs as required.
Old Dec 29, 2019 | 07:32 PM
  #2107
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Mighty Pretty Blue......... and the truck too. !!
F-450 ?
Old Dec 29, 2019 | 09:18 PM
  #2108
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Yes Roy, the pretty blue dually posted by SuperchargedPSD is an F-450. The tires and wheels give it away.
Old Dec 29, 2019 | 09:19 PM
  #2109
SuperchargedPSD
Yes same truck as in the post before my last.
Old Dec 30, 2019 | 09:13 AM
  #2110
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Thanks folks....... Thought it was. I keep debating with myself over a F-350 DRW or a F-450 for my next truck......... (2021)
Old Dec 30, 2019 | 10:45 AM
  #2111
17 Oaks's Avatar
17 Oaks
SaliorMan Roy: Going on my 6th SD since 2010. I have a 450 order, juyst waiting on Ford to ship it.
IF I had it to do over again. Would have NEVER bought anything other than a daully and never bought anything other than a F 450, would have saved a lot of money and bought less SD's in the process...
Old Dec 30, 2019 | 10:52 AM
  #2112
schlepprock250's Avatar
schlepprock250
Well I've never really been interested in a dually. I've had my '99 f250 srw for 13ish years(and still have it), I bought a 14 f250 srw and loved it. They both towed our 30' and now 38' travel trailer perfectly .. Or so I thought.
I recently purchased an '18 F350 dually, and after towing our current 38'travel trailer for the first time (this week) I wish I would've bought a dually to start with. It's so much more stable than the SRWs and they both had an air suspension system.
Old Dec 30, 2019 | 03:39 PM
  #2113
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by 17 Oaks
SaliorMan Roy: Going on my 6th SD since 2010. I have a 450 order. IF I had it to do over again. Would have NEVER bought anything other than a daully and never bought anything other than a F 450, would have saved a lot of money and bought less SD's in the process...
Agreed, and I did exactly this. When the 99 up model year Ford Super Duty first began selling in early 1998, I waited a couple of production years for Ford to work out the first year shortcomings (Ford did, with the 99.5 update), and bought a 2000 model year F-550 DRW personal pickup, paid in cash, and saved a lot of money over the next 20 years, as I've never needed more in a pickup since. I still drive this pickup today.
While I've ordered new chassis cabs for commercial use since, I've never needed more pickup. The weight carrying capacity comes in handy at the unanticipated times like when someone was giving away 6,000 lbs of solid cut stone blocks on craigslist, an unbelievable find. In a flash I ran out there and stacked it all in my pickup, no trailer required, hauled it all safely home (I could feel it, even in an F-550) and was able to put the stone to immediate use, saving a lot of money.
My first Ford pickup was a 1963 unibody F-100, 262 cu in, 3 on the tree. I learned from that pickup that I never wanted a unibody pickup again (corrosion at cab to bed juncture worsened by the flexing at that joint), never wanted a fuel tank in the cab again (fumes and fire/explosion proximity in collision), and could occasionally use 4WD. I replaced the '63 with a 1979 F-250 4x4, which solved the 4WD, solved the fuel tanks (it had two tanks, between the frame rails, not in the cab), and solved the unibody problem. But while the 79 brought a bit more power with 400 Cu In, and a bit more weight carrying capacity (at the cost of sturdiness, the '63 was a tank, having more metal in the dashboard than most trucks had in the entire cab), I then decided I didn't like my head banging against the back window of a regular cab, and wanted the stability of dual rear wheels.
That's when I decided that the next personal truck I buy will be the last personal truck I'll ever need. The 550 CC DRW 4x4 has lasted 20 years thus far. If I can get another 20 years out of it, I'll have gotten my meager money's worth. Beyond that, I'll be too old to drive one anyway, if even here. I just can't see trading every few years for incremental upgrades to what essentially amounts to a tub on wheels. Getting an extra pair of wheels under the tub at the outset will definitely save money over the long run, if the use and purpose of the pickup is to carry heavy stuff.
Old Dec 30, 2019 | 04:30 PM
  #2114
senix's Avatar
senix
My next one will be a F450.
Old Dec 30, 2019 | 09:14 PM
  #2115
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good posts folks....... Thanks for the stories and info......
