Duallys Only
Old Apr 10, 2016 | 05:54 PM
  #1471
senix's Avatar
senix
new upper lip. It is a work in progress.
Old Apr 10, 2016 | 05:56 PM
  #1472
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Looks like you could,pull a tree
Old Apr 10, 2016 | 06:15 PM
  #1473
Lawrencew's Avatar
Lawrencew
Originally Posted by MDSuperDuty
I think they make both. But I don't have a 450. I think when I looked into them for my 350 both types are available. One mounts to the outside of the frame rail (on top of spring pack) and the other on the inside (on top of the axle). I think it depends on if you have a gooseneck/fifth wheel hitch.
Not sure of your year but here's one that mounts on the inside and I selected towing a 5th wheel in the options.
https://www.airliftcompany.com/vehicles/ford/f-450-super-duty-pickup/2015/#l
I wonder if one is any better than other? I can see where the hitch bracket would be in way on frame. I'm makin set of blocks for under leaf pack, 2.5"
Old Apr 10, 2016 | 06:19 PM
  #1474
senix's Avatar
senix
hope so...Still need to tweak it some and get rid of that emblem they put on it.
Have to hook up the lights yet. Neighbor was helping but he couldn't play any longer.
Old Apr 10, 2016 | 07:07 PM
  #1475
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by GIGGER
well done Roy, did you buy flaps or make your own, they look good
no disrespect intended
Hi Gerry.......You are Fine Gerry, don't worry. I purchased them right after taking delivery of Jolly Green......I just pulled up some old photos. Duraflap...Made in Oregon. They give a FTE Discount or a Military discount....
These flaps are heavy. Solid as a rock. I am very pleased with them.
Old Apr 10, 2016 | 07:11 PM
  #1476
golfmedik's Avatar
golfmedik
Nice! I love having the winch on mine.
Old Apr 10, 2016 | 07:30 PM
  #1477
AzSuperDuty's Avatar
AzSuperDuty
CB Radio
Interested in what you guys may have done for a CB radio in your Dually?
Pictures appreciated.
Old Apr 10, 2016 | 07:50 PM
  #1478
Ferguson65's Avatar
Ferguson65
Originally Posted by dualwheels66
Ferguson, why not a 20inch dually wheel, AF and Eagle wheels both have a 20inch wheel. I would love the Eagle series 058 20x9 with Cooper Discoverer AT3 275 65 20.
20X9 is way wider than I would want. The rears will be sticking out past the fenders, fronts likely would too. It already throws enough trash all over itself. I'd rather just keep the skinny tire dually look. Wide tires on a dually is to "bro" to me. And in all honest $ for $ there isn't much difference between the AF 19.5's and the Eagle 20's. AF 20's require adapters. AF also offers clearcoat which Eagle doesn't. Another point is that my truck is a driveway queen. The LT stuff dryrots much faster than the commercial tires I've seen.
My buddy has the AT3's on his 2011 dually and they are not doing very well. Approx 25k and they'll be junk by winter. First truck I've seen them on where I'd call them a failure. This truck runs empty most of the time with a 28' enclosed tag here and there, has a big 5th too but it might move once a year.
Old Apr 10, 2016 | 07:52 PM
  #1479
Ferguson65's Avatar
Ferguson65
There is JUST enough room to sneak the washer and nut between the hitch side rail and frame. It's tight, but doable.
Old Apr 10, 2016 | 08:04 PM
  #1480
dualwheels66's Avatar
dualwheels66
I already have 7000 miles on my AT3 and they look brand new, awesome tire.
I will post a picture of 20' s on a dually
Old Apr 10, 2016 | 08:17 PM
  #1481
Ram1955's Avatar
Ram1955
Firestone air bags
I have another question, guys using air helper bags, do they mount on top of leaf pack, or on top of axle ? Specifically for my 450
I put Firestone RydeRite bags on my 350 w,max tow. They go on the inside and have a bracket that fits to the frame and fasten to the top of the axle. There is also a ubolt that goes around the spring block. I have the factory fifth wheel prep and there were no problems.
Old Apr 10, 2016 | 09:01 PM
  #1482
Mystic_Cobra's Avatar
Mystic_Cobra
Adding the Wide Track front fender flares might be another good option for minimizing the chips on the front of the dually fender. PLUS, they good great!
Old Apr 10, 2016 | 09:04 PM
  #1483
dualwheels66
here is one
Let's see your 11'-15' crew cab dually. - Page 54 - PowerStrokeArmy
Old Apr 10, 2016 | 09:07 PM
  #1484
Lawrencew's Avatar
Lawrencew
Ya its a 450 so it already has the big flares and large flaps. And Ya I agree they look gooood. With no race today and snow falling outside again, I found myself having a whiskey sitting in shop just admiring my big beauty
Old Apr 10, 2016 | 09:13 PM
  #1485
Ferguson65's Avatar
Ferguson65
Screams SEMA bro-dozer to me. Just not a look I'm into. I'd love to see if there is actually any space between those rear tires. Doubt it.
