AE vs IDS clone
Old Jul 30, 2017 | 08:30 PM
  #76
skrub's Avatar
skrub
IDS CLONE
OK Im new here and looking to get an IDS Clone asap, Need to get my 06 250 diesel up an running as I have to move at the end of August. Need to do a contribution test to see which injector im having issue with. YaHiko if you have any that will work with my truck I have Paypal ready and ready to use it. I do all my repairs on my own cars and trucks as I dont trust shops, Im a technician myself and know how the system works. Again thanks for any help.
Old Jul 30, 2017 | 08:48 PM
  #77
Yahiko's Avatar
Yahiko
You want to PM me because I do have a new one sitting in a box right now.
Old Jul 30, 2017 | 10:05 PM
  #78
skrub's Avatar
skrub
will it let let me pm you as i new here
Old Jul 31, 2017 | 12:29 AM
  #79
Yahiko's Avatar
Yahiko
Sent you an Email
Old Jul 31, 2017 | 05:35 PM
  #80
skrub's Avatar
skrub
Hey Sen thanks again for quick response on emails, if it lets me Im going to post up a youtube link on what my truck is doing.
Old Jul 31, 2017 | 11:57 PM
  #81
Yahiko's Avatar
Yahiko
The best thing to do is start a new thread on the main 6.0L board.
Not everyone looks in each thread. So posting the video here will not
get you as good a response as the new thread would.
The link for a new thread can be found on the main page.
https://www.ford-trucks.com/forums/forum107/
It's on the left side of the page just above where the threads are.
Once you have a thread started I can ask the Mod to move the
video for you.
BTW I talked to the person at the UPS depot and she though that
is things move well you might see the package on Friday. Would be nice.
Old Aug 1, 2017 | 12:06 AM
  #82
skrub's Avatar
skrub
video for you.
Oh I was just showing you what my truck was doing, that is why I need a IDS scanner tool to see what the hell it's doing
Old Aug 1, 2017 | 12:13 AM
  #83
Yahiko's Avatar
Yahiko
I see.
How does it feel when your sitting in it?
I have a low tech way to tell if something is running rough.
Sit a cup of water on the floor and watch the ripples. it
won't tell you what injector is acting up.
Old Aug 1, 2017 | 12:14 AM
  #84
skrub's Avatar
skrub
I see.
It's not to ruff but I can tell it's some kinda miss or something
Old Aug 13, 2017 | 04:04 PM
  #85
skrub's Avatar
skrub
Is there a thread here that gives a good walk around on how to set the ids up? I have tries several ways and still no go on getting it to work. If anyone can point me in the right direction that would be great
Old Aug 13, 2017 | 11:18 PM
  #86
Yahiko's Avatar
Yahiko
What version of IDS are you using?
We have found that v86 works well for testing the 6.0L
the only issue with v86 is programming. You have to use one
of the versions and you also need the files to install.
Now if you tried the higher level like v101 and then want to go
back to v86 you will have to do a recovery.
Check this video at about 6:22 in if you need to do a recovery.
Old Aug 14, 2017 | 09:18 AM
  #87
skrub's Avatar
skrub
I have installed the v86 on a vm windows xp pro. I went to the ford folder and used that version of v86, after install I did the patch file before starting the IDS. Now question is do I need to have the module hooked up to the laptop when installing and also what about the calibration file I a have seen done, do I need to do that. I dont have access to a laptop with just windows XP, all I have is one running win 7 pro. I have the virtual machine installed. I have looked for a video that has a complete install of the IDS but all the ones I have found really done explain it to well.
Old Aug 14, 2017 | 01:30 PM
  #88
goosehunta's Avatar
goosehunta
I was having some issues trying to run V86 on VM winXP. I ended up uninstalling the vm and ids and reinstalled on win7 and worked fine. Not sure what was catching but XP just didn't like it for some reason.
Old Aug 14, 2017 | 03:36 PM
  #89
skrub's Avatar
skrub
Hmmmm Ill try win 7 , wonder if it matters that mine is win 7 Pro? will see i guess, now should I have the module hooked up so windows sees it and installs te drivers for it at the same time the ids is loading? or just install the v86 and then hook it up. I dont know if there is an order this has to be done to work right.
Old Aug 14, 2017 | 04:12 PM
  #90
Yahiko's Avatar
Yahiko
You do not want to use the Windows wireless drivers if your using the wireless connection.
