Sorry to dig up an old post but I was wondering if anyone had a run down on the different software versions for the IDS.
I have a clone and it's working fine with v86 and the patch.
Does anyone have a list of what's new in each of the other versions and if they have a patch available like the v86 software does.
I have not seen anything like this around and I've been digging for a couple weeks on this now.
Anything above V86 seems to have to use VMware do deal with the date issue
of the trial software. If you have a 6.0L in a truck of Ex then V86 is really all you need.
Well it looks like the pipeline has opened up again.
I should have one in my hands first of the week.
EDIT :Just a side thought. I can also get the elm327
units but will need to look into what the cost would be.
I also need to see if I can mix up the types of have to
order a lot of IOS, Android or some of the other options.
The newest one will be here Monday evening if DHL tracking info is correct.
I only wished I could find someone that also has the data recorder dongle
with there package. But I have had zero luck on that point.
Anyway just as soon as I get this one checked out I will know if this supplier
is good or not. I really hope for good.
Does anyone know if it can be used to refresh a new PCM in a 2015 mustang. I am converting my manual to an automatic and I need a IDS to add my VIN to the auto computer.
