Post Your Gauge Clusters!
Old Jan 3, 2015 | 09:29 PM
  #61
crazed87bronco's Avatar
crazed87bronco
Originally Posted by trozei
Psst... that's purple.
Originally Posted by dwil
Chromey Purple?
Atleast you can tell it's purple it looks more blueish in the pics. The chrome pieces are Beside the purple the 3 instrument cluster lamp housings. Small pieces but I got the stock fuel line from the in cab tank down through the cab floor chrome coated as well.
Old Jan 3, 2015 | 09:51 PM
  #62
trozei's Avatar
trozei
The only powdercoat I've done was on my dirtbike.
Attachment 290874
Old Jan 3, 2015 | 11:10 PM
  #63
Ford_Six's Avatar
Ford_Six
Custom gauges are not at all hard to come by.
Those are semi-custom, from Speedhut according to the build thread.
Sent from my Brigadier using IB AutoGroup
Old Jan 4, 2015 | 07:45 AM
  #64
f100today's Avatar
f100today
I do believe that if speed hut does not have the color you want on their website, you can download the color you want to their website and get what you are looking for. You can virtually download anything and put it on your gauges over there. Even a picture of say; your significant other. lol
Old Jan 4, 2015 | 08:06 AM
  #65
elgemcdlf's Avatar
elgemcdlf
Wouldn't that be akin to having a name tattooed on?
Old Jan 4, 2015 | 08:53 AM
  #66
crazed87bronco
Dang double post
Old Jan 4, 2015 | 08:54 AM
  #67
crazed87bronco
In the world of custom gauges now days a lot of these companies will build you just about anything you want. Not hard at all to change just the background color. I'm still not looking forward to the price tag on all my gauges I'll be needing. Having your significant other on the gauge faces would just be scary haha.
Old Jan 4, 2015 | 10:44 AM
  #68
ultraranger's Avatar
ultraranger
...the gauges would be easier undone than the tattoo.
Old Jan 4, 2015 | 01:44 PM
  #69
Gembone's Avatar
Gembone
has anyone tried the LED light kits in the stock cluster? My biggest problem is the visibility of the signal lights and gauges in night and bright light situations.
Example: if the Vegas sun is behind me I can't see if my turn signal indicators are blinking or not. Also at night the yellowish lighting from stock bulbs glare on the window screen making the gauges hard to read.
I think the LEDs would help during the day by making them brighter. I also feel that this could multiply the glare problem at night.
So can anyone who has tried these enlighten and inform me on if they made things better or worse?
Old Jan 4, 2015 | 02:08 PM
  #70
Endure's Avatar
Endure
LEDs
I tried the small LEDs, Two green for signal indicator, Blue for high beam, adding an orange for preheat, so I can see when my timer shuts off.
The truck started out as gas. I bought the auto meter gauges. Then we decided to put in a diesel, so I added the glow shift gauges.
I had a buddy cut out a plate that I gb welded into the original cluster.
http://cimg2.ibsrv.net/gimg/www.ford...5d78aeb8ce.jpg
Old Jan 4, 2015 | 02:20 PM
  #71
Gembone's Avatar
Gembone
So what did you think of them and how did they differ from stock?
Old Jan 4, 2015 | 02:21 PM
  #72
ultraranger
I eventually plan to convert to LED interior/exterior lighting but currently, I haven't put a lot of research time into this subject to know what all is required to do this, because I'm not to that point, yet.
However, in the brief time I have spent reading on this subject, it seems I remember reading that the factory rheostat (the instrument cluster dimmer switch), doesn't work with LEDs.
The LED instrument cluster lights will be about 4 times brighter than the stock 1445 incandescent instrument cluster bulbs. This may be a good thing or, it may be bad if the brightness is blowing your eyes out, if you can't control the brightness off the stock rheostat.
There are LED compatible rheostats available that will give you the ability to control their brightness.
The rheostats range in price from reasonable to "oh my God!!"
I don't know anything about this particular one but, it's just one of the first ones that popped up, when I searched just now.
MaxPulse MaxDim instrument panel dimmer pulser max pulse max dim pulsar aircraft wingtip landing light pulsers flashers
Old Jan 4, 2015 | 02:30 PM
  #73
Endure's Avatar
Endure
Haven't actually drove the truck yet. Hope to have it on the road for the spring.
I used the 1/4 LEDs. They are bright for there size, I don't think I would want to go any bigger as they would be too bright.
Kind of hard to see them in that picture, but signal indicators are just above the centre gauge.
Working on my Crewcab these days. In a couple weeks I will get this one back in the garage, I will try and get a picture with the LEDs on.
Old Jan 4, 2015 | 02:32 PM
  #74
Gembone's Avatar
Gembone
These are the type of LED replacement bulbs I am referring too(Found in the ever helpful Tech thread): 1961-79 Ford Truck & Bronco LED Gauge Light Conversion Kits - HiPo Parts Garage
They supposedly have an option that has dimmer capability.
Old Jan 4, 2015 | 03:17 PM
  #75
dwil's Avatar
dwil
I have ordered some red and white. Cluster isn't ready to go into truck just yet. When I do, I'll report back.
