I need an old guy....
Old Jan 27, 2014 | 04:50 PM
  #271
351Cleveland C4's Avatar
351Cleveland C4
No I'm not against ditching the points, but they seem to be working fine for now.
Old Jan 27, 2014 | 06:00 PM
  #272
JEFFFAFA's Avatar
JEFFFAFA
Try checking the timing. You got a comedian for a freind who has a Dizzy wrench?
Old Jan 27, 2014 | 06:04 PM
  #273
Copper67440's Avatar
Copper67440
Convert the distributor to electronic and get a new coil.
Old Jan 27, 2014 | 06:17 PM
  #274
351Cleveland C4
I swapped the coils. No diff.
I started er up and let her idle. ( she idles now) for about 7 minutes it was running normal, then started doing it again. ( it's the classic movie breakdown sound, knock sputter knock knock die)
I wait a minute and start it back up, runs normal again.
Old Jan 27, 2014 | 06:48 PM
  #275
351Cleveland C4
Ok so since last post the problem seemed to have went away. It was running about normal so I took it out for a drive. I left it in first gear and drove a couple miles at different Rpm to see if i could find the problem. It runs worst between 1500-2000 rpm. Above or below that it did ok.
In the last half mike of my little test drive, the problem returns full force, coughing sputtering popping backfiring kicking knocking and dieing out.
Imma pop the top off my carb and see what I see. I'm thinking maybe I got a jet plugged up or something.
But it might be ignition related too cuz my tach is freaking is out when it happens.
Old Jan 27, 2014 | 07:06 PM
  #276
351Cleveland C4
I hope I just got a horribly bad batch of gasoline. It's all the right symptoms.
Old Jan 28, 2014 | 08:23 AM
  #277
BobbyFord's Avatar
BobbyFord
You've wasted way more time & money guessing and throwing parts at it than you would have by paying a qualified mechanic to diagnose your running condition. Just saying.
Old Jan 28, 2014 | 08:34 AM
  #278
Copper67440
Is the coil you swapped new? Get rid of the points.
Old Jan 28, 2014 | 12:05 PM
  #279
351Cleveland C4
Coil wasn't new, but is known to be good.
I just ordered myself a pertronix kit. Even though I don't believe it's the points right now, I suppose it could be.
It's a completely intermittent problem.
Old Jan 28, 2014 | 12:28 PM
  #280
arctic y block's Avatar
arctic y block
I had a screw that held the points down get under the breaker plate and
do this. Took for ever to find it as it was that way when I got the truck.
I knew the prob was with the dizzy so I took it out and was taking it apart
when I found the screw. Just a thought. And putting in an electronic exciter
would not fix something like this.
How are the bushings in the dizzy? Any side play in the shaft?
Old Jan 28, 2014 | 12:37 PM
  #281
orich's Avatar
orich
As often as you keep changing parts out it's ez to over look the small little things. Like loose or frayed wires in the dizzy. Or a bad dizzy wire to the coil that looks good on the outside of the insulation.
But all in all if no problems found then, I can only think of one more thing. You were born on Friday the 13th.
orich
Old Jan 28, 2014 | 01:53 PM
  #282
JEFFFAFA's Avatar
JEFFFAFA
Try deleting the tach for a try. Delete it at it's source. My guess is the tach or it's wiring is messing up the ignition via a short,etc.
Old Jan 28, 2014 | 02:07 PM
  #283
351Cleveland C4
Hmm. Now today I can't even get it started. It will crank fire a couple times and die.
Old Jan 28, 2014 | 03:55 PM
  #284
arctic y block
Good. Now it's developing and we are getting some place. Pour a small shot of gas down the intake. If it starts and runs better for a few seconds than I would say it's fuel delivery.
If it don't start at all then prolly flooded and check for spark. Should be a bright
blue spark at the plug or plug wire.
Let us know.
Old Jan 28, 2014 | 04:06 PM
  #285
arctic y block
Have ya disconnected the Tach yet?
