I need an old guy....
Old Jan 9, 2014 | 04:40 PM
  #196
orich's Avatar
orich
Originally Posted by 351Cleveland C4
Well my intake just showed up. So now I'll finish my carburetor and I'll put it on probably early next week.
I'm hoping to heck That this thing will run better with them.
see step #5 I think where your having troubles.
Here's a link maybe you should check out for intake fitment.
http://www.google.com/url?sa=t&rct=j...59186614,d.cGU
Old Jan 9, 2014 | 04:52 PM
  #197
351Cleveland C4's Avatar
351Cleveland C4
Double post.
That is a good link. I will check it all out when I put it on. Thanks orich.
Old Jan 9, 2014 | 05:26 PM
  #198
ford6867's Avatar
ford6867
Well my intake showed up today. Now I just gotta finish my carb and find a day to put it on. Probably early next week.
I sure hope it runs better with this stuff.
good luck, praying for ya!
Old Jan 9, 2014 | 05:48 PM
  #199
JEFFFAFA's Avatar
JEFFFAFA
I think you just solved the mystery with this link Rich. Wish the Forum would have let me Rep ya.
Old Jan 9, 2014 | 06:34 PM
  #200
BobbyFord's Avatar
BobbyFord
I would remove the intake carefully, so as not to disturb the gaskets. Also, carefully inspect the gaskets once they're off for any witness marks indicating a compromised seal near the affected cylinder intake ports. You want to decisively find the issue while the motor is apart.
I generally like to glue the gasket to the head, around the intake port, using Gaskacinch. This adds a little insurance against gasket slippage when setting the intake onto the motor.
Old Jan 9, 2014 | 06:52 PM
  #201
orich's Avatar
orich
I seen where silly putty use for checking clearances for valves to pistons. I'd say you could do the same with checking intakes also..orich
Old Jan 9, 2014 | 07:09 PM
  #202
ford6867's Avatar
ford6867
One more thing to remember, if your block and heads have been decked (or milled) your intake ports might not line up just right. I have had to get intake manifold cut so intake ports would line up. Also used thin metal gaskets to get runners to line up with intake ports on heads. This is something that should be checked regardless. Some performance shops use a scope and run it down intake manifold to check alignment. Intake gasket could interfere with air flow also.
Old Jan 10, 2014 | 12:33 AM
  #203
mkoch96's Avatar
mkoch96
I just thought of one other thing that would be very easy to check while you have it apart. You may want to check the threaded holes in the head that the intake bolts thread into. Maybe one of them is a little buggered up not allowing you to tighten the intake up properly. Or maybe check the length of the intake bolts. If they are too long, they may bottom out before the intake manifold is tight.
Old Jan 10, 2014 | 07:32 AM
  #204
fe390pc's Avatar
fe390pc
mkoch96 that is a very good thought.
Old Jan 10, 2014 | 07:39 PM
  #205
351Cleveland C4
You can bet I'm gonna be checking all that and more this time around.
I think I'll end up doing this Monday or Tuesday. Right now my biggest concern is getting my carb cleaned out. I took it apart and it was just terrible inside. Rust and dirt everywhere! I'm going to have to spend a few more hours just cleaning the carb out before I can start reassembling it.
Old Jan 10, 2014 | 07:59 PM
  #206
BobbyFord's Avatar
BobbyFord
Time to invest and install a better fuel filtering system, then. I installed a 100 micron filter at the tank and a 40 micron filter near the carb. You don't want to have the same thing happening to a new carburetor.
Old Jan 10, 2014 | 08:08 PM
  #207
351Cleveland C4
On my current setup I have a 20 micron filter pre pump and a 12 micron filter at the carb. I'm gonna keep it that way when I swap carbs.
I don't know what the story is behind all the dirt inside this other carb. It was about the dirtiest carb I've ever seen.
Old Jan 10, 2014 | 08:19 PM
  #208
BobbyFord's Avatar
BobbyFord
Might be a good time to R&R the tank for a cleaning and evaluation.
Old Jan 10, 2014 | 08:42 PM
  #209
351Cleveland C4
Did that already when I got the truck. I got it pretty clean. What was left is getting filtered out. It's almost all clean now after probably 4 filters.
Old Jan 10, 2014 | 08:48 PM
  #210
BobbyFord's Avatar
BobbyFord
I wish you luck. I don't think you're too far away from finding the solution to your issue.
