I still need to address the rear springs. I got the basic kit with the plans to add-on components later (ladder bars, dual shock kit, etc). The factory springs are still there, but i got new front lift springs. The *** sits a bit lower and that's pissing me off... I'm not a fan of the "baja look".
I was gonna go with 350DRW springs, but then I found out Rough Country lift springs are cheaper, and I'll be eliminating the blocks. Sold.
I wish I had gotten the dual shock kit from the start, but thats super easy to install and is wicked cheap. And easily done in the driveway because all the rusty hardware that was there has been replaced with all new shiny junk.
if you were gonna get traction bars anyways, you could have just gotten a little bigger block or an add a leaf
Right now it's got both lifting blocks - factory and the lift one. I want to replace them both (or just the lift one) with a lift spring. That was the plan all along, the block in the back was just to lower the initial cost of the lift. I can add on parts later. I'm definitely going with traction bars eventually (yours are wicked nice BTW), so I'll get the hardware kit for those and do the brackets at the same time i swap the springs out.
If you have both blocks installed, weld them together. I was wheeling with a guy a few years back with a cummins on 38s. He had 2 blocks stacked, the stock block and then a lift block. Anyways, he wromped on the skinny pedal and the torque rotated the axle housing, knocked the lower blocks out, and broke the drive shaft/u-joint/yoke where it meets at the axle housing. I would call it catastrophic failure.
Here is the truck, but I didn't get any shots of the problem.
I agree I plan to throw a 12v in mine...only thing is getting it past Massachusetts inspections lol.
True... I know there's ways around, it just involves a lot of electronics. You basically need to keep the old PCM and make it think it's running a clean motor. Back in my car days, there was a kid on one forum who did it with his IS300. The aftermarket computer ran the car, but a series of diodes and whatever other chips were used to make the old PCM think it was in charge - and the inspection station listened.
