Sponsored by: Real Truck
WickidPissa Build Thread
Old Jun 27, 2013 | 05:09 PM
  #91
67nukeford's Avatar
67nukeford
Veteran: Navy
Aw, man! I want one of those newer tailgates!!LOL! Nice job, Craig!
Old Jun 28, 2013 | 09:12 AM
  #92
WADE MMT/PSD's Avatar
WADE MMT/PSD
Former Vendor
Originally Posted by WickidPissa
Wade, this one is for you buddy:
LOL
Old Jun 28, 2013 | 09:22 AM
  #93
WickidPissa's Avatar
WickidPissa
Tailgate:
Been too crappy out to safely paint - project's on hold until nice weather unfortunately.
Courtesy Light Module:
Broke out the breadboard last night and grabbed some parts from radio shack - created a simple module that when triggered by a lock or unlock (pulse to ground), activates a 30 second closed circuit. Ordered 4 relays for the individual light circuits, just a matter of building the unit and installing now...
Old Jul 17, 2013 | 08:33 AM
  #94
WickidPissa
Really getting anxious to paint the tailgate, but this humidity isn't ideal for it. Been working on a newer revision of the courtesy light module (which, as a reminder, is now a project driven strictly by the fact that a friend said it was "impossible" lol).
I added adjustability ***** - one for how long they stay on for, and one to adjust how dark out it has to be for them to come on. The printed circuit board is pretty much ready to make - never done pcb etching before, but I'm gonna take a swing at it.
The one on the left is the smaller board for the little windshield module that holds the light sensor, and two *****. Similar in size and shape to a remote starter antenna, light, and button box; about an inch wide, inch and a half tall, and half inch thick, black plastic (already got it from ebay for $3 lol).
Old Jul 17, 2013 | 09:09 AM
  #95
wizkid00104's Avatar
wizkid00104
I built a robot in college and did etching several times. Ferric chloride ruins anything it touches (ie clothes) so be very careful. It will also turn your skin brown/orange.
The etching process works very well, but you must be patient. When I did them, we printed our pattern out on a laser jet printer. We then wiped the entire copper side of the board with ferric chloride to ensure it was clean. Rinsed it with a little water and dried it off. We taped the ink side of the printout to the board and ran it through a heat shrink laminating machine to transfer the ink. Then ran it through again using this special transfer paper (it was green) that actually sealed the pattern to the board. Then we broke out the rubber gloves, put ferric chloride in small tub for the sink, and then gently rubbed the board with a sponge. Don't rub too hard though, you'll remove the traces you want to keep. Then there was a chemical to remove the toner, and finally there was a chemical that silver plated the copper to prevent oxidation.
When you are done, check all traces for continuity with the multimeter. It can save you a huge headache later. If you accidentally broke a trace, its nothing a little solder bridge can't fix (Usually...)
You can then drill your holes for the through hole components. I have two of the bits, but I can't remember the sizes. I'd have to look tonight.
It is a fun project and can be very rewarding
Old Jul 17, 2013 | 09:52 AM
  #96
WickidPissa
The laser printer method is definitely the way i'm going (hence this picture - it's the reversed version I'll need.).
Looking to find a kit that has everything i need, with chemicals and bits would be nice - i dont think i have any bits that tiny....
eBay has some companies that accept gerber pcb drawings to manufacture really nice green filmed, white printed, drilled boards - but i cant generate gerber files, and the free version sucks.
Old Jul 17, 2013 | 10:13 AM
  #97
wizkid00104
I had to do mine on a version ported from DOS. It was free when it was launched in 1988. I did this project in the spring of 2009...
Believe it or not, radio shack use to have a lot of the stuff. I went to the local on in college and they had two bottle of ferric chloride on the shelf.
Never looked into buying a kit, but I can get you the drill bit sizes tonight if that will help.
Old Jul 17, 2013 | 10:30 AM
  #98
WickidPissa
Ya, I've been going to eBay, Radio Shack, and You-Do-It in Needham. You-Do-It had big bottles, I just need a small one.
I still need to get an exact list of what I need as far as chemicals, and how much is required for a board that big... i don't see myself needing leftovers any time soon.
Old Jul 17, 2013 | 11:21 AM
  #99
wizkid00104
I used a 32 oz bottle when I did it. That gave me enough to immerse the board in it. It was also the only bottle available.... But anyway, when you are done you either throw it out or just pour it back into the bottle. Its not a one time use liquid. You can use for a good while until it becomes enriched with copper.
One other thing I thought of. How wide are the skinniest traces? You may want to increase the line size by a few mils to keep it safe. I want to say that 10 or 15 mil was the minimum width my professor said we were capable of doing by hand. Anything skinnier needed to be left to the machines.
Old Jul 17, 2013 | 11:37 AM
  #100
WickidPissa
2 1/4 points (line size in MS Visio) = 31.25 mils, according to the Google machine. Seems like I'm safe. That board pictured is just under 5 1/2" x 4".
I didn't do any formal calculating or engineering about the larger traces - how thick the board copper is vs. how much of a load can pass through them at what widths. I'm sure there's a calculation or something. They are currently a perfect 125 mils, and will be fused at 10 amps, though i may end up needing different fuses. the bottom is a fuse block, for cargo, aux cargo, fog, aux fog, reverse, aux reverse, and mirror lights. Some will be relatively low load, as the factory relays are still in place, but some will directly carry a load.
EDIT: I just checked online, and it seems my traces are plenty wide enough. It would stink to fry one when the lights go on. Also thinking about making the relays plug-in instead of soldered. (I already have PCB mount relays).
I also haven't figured out how to do the connectors on the outside. Having done numerous remote starters, I want it to basically be wired the exact same way, with one big heavy connector for the higher load leads, and a couple smaller ones for the smaller leads. The top left of the picture is of the two separate boards, and between them could be a premade 6 or 8' lead, exactly like the one that goes from a remote starter brain to it's antenna module It'd be nice to get one of those jumpers premade, and get the ends to PCB mount. Looking on eBay now, and will check locally later.
Old Jul 17, 2013 | 11:57 AM
  #101
wizkid00104
I was off on my number then lol. I don't know where I got 10 to 15 lol.
This should help you make sure your traces can meet the 10 amp requirement. It's fairly simple.
http://www.ultracad.com/articles/fusing.pdf
Old Jul 17, 2013 | 11:59 AM
  #102
WickidPissa
10 to 15 makes sense for a minimum... That's tiny, and anything smaller probably wouldn't work.
I was just looking here:
The CircuitCalculator.com Blog » PCB Trace Width Calculator
I can't find online how thick the Radio Shack board's copper is though.
Old Jul 17, 2013 | 08:21 PM
  #103
jakgod3's Avatar
jakgod3
This is a great build! Really getting me motivated to work on my truck and start putzing on it in my free time.. Keep up the good work!
-Jared
Old Jul 17, 2013 | 08:30 PM
  #104
wizkid00104
Digikey may be able to get you closer to a thickness. They will at least tell how much copper was used on a given board dimension which would let you calculate it. But that is getting really in depth...
Invalid Request
Old Jul 18, 2013 | 09:17 AM
  #105
WickidPissa
Invalid Request
I just revised the drawings and added the jumpers to the opposite side, as well as additional very large thick traces. I think I'll have more than enough copper to carry the load. The current from all the lights will be going through that bus, so I'll probably have to fiddle with fuses to find an appropriate one. I was going to calculate the load from 2 H10 bulbs (fog), 2 3156 (reverse), a 906 (cargo) and a couple 194 equivalent (mirrors). Then figure that doubled since there's provisions for aux outputs, plus some wiggleroom so the fuse is bigger than the load but smaller than the limits of the amount of copper i have that main power lead will have it's own external fuse, though I don't think that'll be a problem.
Another good reason these things are good to talk out with someone else, thanks for all the input.
