Rebuilding E4OD
Old Jul 31, 2015 | 02:43 PM
  #541
orygun202's Avatar
orygun202
great web site.
I would like to thank all those who make this site available to all of us who keep trying to make our Fords better. I want to wish Dieselzen a good season and ask him for the very popular file has has given to many while i have watched trying to get one also. I have waited to rebuild my E4OD on the 97 F250 4X4 with much anticipation. I have the torque converter and rebuilt kit (without the steel) ready to go and await the zip file.
Thank you Dieselzen ahead of time for this fileI used to be on this site years ago but have been busy keeping old Fords running. now i am down to 2 vehicles.
My age is not slowing me down as I continue to learn even at 71.
Keep the faith, orygun202
Old Aug 18, 2015 | 02:08 PM
  #542
Tom D's Avatar
Tom D
I can't believe how many years the requests for a E40D rebuild zip file have gone on. Thank you all for helping us all with it. Oh yeah..could you please send me a copy? I would really appreciate it.
Tom D
Old Sep 8, 2015 | 06:35 PM
  #543
Stephen Parr's Avatar
Stephen Parr
Desperately need help now
i have a 1996 f150 4x4 Eddie Bauer with 192k
My trans (e4od) acts like it's in limp mode
No lights flashing (had a column from 94 f150 put in
It had o/d button and light)
No dash lights on either. I replaced neutral
Safety switch and cleaned vss and un hooked
Negative battery post for 15 min
Truck hard shifts and does NOT have passing gear if I floor it my engine
Revs up but truck won't go until I let off
Throttle a bit. Truck shifted fine when I first got it
Also sprayed contact cleaner on
Safety switch plug, throttle sensor, and plug on trans (round plug)
Old Oct 25, 2015 | 09:31 AM
  #544
FordCwazyGuy's Avatar
FordCwazyGuy
Is this Zip file and info still available?
I have a 91 F250 5.8 2WD I use to haul a few trailers and junk
The trans shift fine in all forward gears,but on cold mornings takes a while to go in forward gear,after tht it's good for the day,plus reverse gets a lil slip when warm.
I bought on the cheap a E4OD from a 93 F150 4.9 with low miles,the guy tore it down building a race truck..the linkage is different but easily do-able when i turn the linkage upside down and drill a hole for the 91 manual rod linkage..
The major problem is the 93 trans doesn't have the ring machined into the tail shaft for the VSS(speedomoter cable) for the 91...they it in the rear differential
i'd like to stay cheap as possible,so i am thinking of swapping out the shafts to make it work with my VSS,i've been told the trans won't shift right without it
From what i've researched is the whole guts of the trans has to come out in order to change to change that shaft
Old Oct 26, 2015 | 07:49 PM
  #545
EgoTrip90's Avatar
EgoTrip90
Good evening. I too would like a copy of this miracle if still available.
J3st3r90@Yahoo.com
Old Dec 4, 2015 | 12:46 AM
  #546
jmpape's Avatar
jmpape
Hello
Im late to the party but could I also get a copy of the zip fil
Thank you
Jay
jmpape@aol.com
Old Dec 5, 2015 | 06:31 AM
  #547
petepetersen's Avatar
petepetersen
Hello- I would to rebuilt the E4ODd in my 1994 F250. Please send me the file. - Thanks
Old Dec 5, 2015 | 07:57 PM
  #548
koyoteturtle's Avatar
koyoteturtle
E4OD Trans
Hi, I have a 96 Ford Bronco with an E4OD, somehoe the Trans filter media got sucked up into the transmission and its looking like it will need a rebuild. Could I too get the zip file?
Old Dec 6, 2015 | 03:38 AM
  #549
petepetersen
While searching online to find the zip file, I found i a link to a e4od rebuild write-up here - E4OD rebuild.
also a good tear down video here-
Old Jan 2, 2016 | 11:43 PM
  #550
Agmorris5's Avatar
Agmorris5
Rebuilding E4OD
Is there any way I could get that zip file?
Old Jan 3, 2016 | 01:37 AM
  #551
petepetersen
I would like to get that E4OD rebuid zip file too. - Thanks
Old Feb 5, 2016 | 10:03 AM
  #552
Zombified Apple's Avatar
Zombified Apple
I would like that zip file.
Old Feb 5, 2016 | 10:22 AM
  #553
Flareside_94's Avatar
Flareside_94
zip file request on transmission
Hi, I have a 94 flareside and would also like a copy of the file.
thanks in advance
Old Feb 16, 2016 | 03:09 PM
  #554
Eliminatr's Avatar
Eliminatr
Zip file Request
Just wondering if folks are still getting the zip file. I'd love to have the file as I need to rebuild my E4OD.
Jamie
Old Apr 24, 2016 | 06:37 PM
  #555
badasssapper67's Avatar
badasssapper67
I also would love to get that zip file.
