tymar comments, use this thread
Old May 28, 2003 | 01:07 AM
  #181
JoeBoost's Avatar
JoeBoost
Motoxman -
All you need to do is get a piece of 4'' pipe , about a inch wide , and tap a hole for the filter minder to go into. I believe someone had a pic of their setup , with this done to it.
So basically , it would go :
Filter - inch wide piece of 4'' pipe - then rubber tubin to turbo
Old May 28, 2003 | 11:09 AM
  #182
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
How long do you leave the #15 fuse out
Just pull it out and put it back in. The PCM dies and clears as soon as the fuse comes out. You will have a brand new PO603 code when you are done, but it dosen't hurt anything.
Old May 28, 2003 | 02:36 PM
  #183
Motoxman_117's Avatar
Motoxman_117
What will resetting the pcm do exactly?
MotoX
Old May 28, 2003 | 02:37 PM
  #184
Motoxman_117
JoeBoost
How will the minder seat into the pipe without leaking?
MotoX
Old May 28, 2003 | 03:12 PM
  #185
pcwirepro's Avatar
pcwirepro
The filter minder has a rubber o-ring in the stock air box. Drill the hole in the new section of pipe to fit that. Keep it tight so you get a good seal. Here is a Pic
Old May 28, 2003 | 06:25 PM
  #186
99f250's Avatar
99f250
pcwirepro--
what are the chances of getting water into the turbo with that intake? read below.......this was posted on my jeep club about putting a diesel in a jeep.
IF, you get a ford power stroke, make SURE you get a snorkle!!!
> My friend/co-worker has an F-350 4x4 w/ turbo power stroke deisel. He
> just lost $15,000 driving through 6 inches of water with it! The
> breather system on these trucks is at the bumper level, if you know
> anything about deisels a teaspoon of water will absolutly destroy one if
> sucked into the engine. water doesnt compress very well, especaily at
> 36:1 compression, lol
> The outcome 2 broken rods, busted pistons, broken block.... Ford
> wouldnt honor the warranty when they found alittle water in the
> turbo/intercooler. A very very very BAD engineering defect on Ford in
> our opinion! Cost was $15,000 to fix.
Old May 28, 2003 | 07:01 PM
  #187
alanscott's Avatar
alanscott
Is the story true, or is it smoke comming at ya?
One little glitch is the compression ratio, it's 17.5:1.
Old May 28, 2003 | 10:31 PM
  #188
cookie88's Avatar
cookie88
FTE Emeritus
When it rains hard I have to drive through 12" of water to get out of my driveway, and what about the boyz running water injection on their hot rod PSD's, or any diesel for that matter?
It just clears any stored codes that may, or may not, be affecting your driveability.
Old May 29, 2003 | 12:47 AM
  #189
pcwirepro's Avatar
pcwirepro
This kind of filter has been run on diesels for years. No question you can screw things up with water, but if you're in water that deep it will get in a factory box as well. How many PSD have you seen runnibg around with snorkels. I have a direct shot from the grille of my truck to the filter (zoodad mod) and have driven through some pretty rough rain and snow at 65 mph or faster without a problem. This is just one of those mods that make the little boys nervous. If you're worried , don't do it. If you do do it and are still nervous, put it all back the way it was and blame it on some noise as others have done. No worries on my end.
Old May 29, 2003 | 08:30 AM
  #190
99f250's Avatar
99f250
i was just wondering if driving thru a monsoon here in az is gonna have any impact on the saturation of the filter. im kinda getting used to the turbo 'screaming' with the intake mod!!!
jeff
Old May 29, 2003 | 09:09 AM
  #191
FTE Ken's Avatar
FTE Ken
Here are some flow numbers. The Magnum Force flow numbers are as higher over the Tymar as the Tymar is over stock.
Old May 29, 2003 | 01:39 PM
  #192
Motoxman_117
Wow! Those are some diff numbers than i expected. How did you get those numbers ken? I might go back to my magnum force.
MotoX
Old May 29, 2003 | 01:48 PM
  #193
FTE Ken's Avatar
FTE Ken
These numbers were supplied by AFe after I discussed the Tymar and the possibility of them producing a filter system with a paper filter. I was told, basically, "why would AFe want to produce a system that flows less?" and received this fax from them this morning.
Don't take them as Gospel, just as you shouldn't take the numbers Tymar gives as Gospel. Of course Dale is going to hype his Tymar system, just as AFe is going to hype the Magnum Force. The truth probably lies somewhere in between... (which would still mean the AFe flows more).
Old May 30, 2003 | 11:19 PM
  #194
slazgolf1's Avatar
slazgolf1
-comments edited by moderator-
I just purchased the Tymar air filter for my '99. Much less turbo lag and more responsive than the stock setup.
I recommend the open air filter system.
I don't care what Banks is doing, I don't work for any of these companys, and I'm not plugging anything.
It just works better!
Done!
Old May 31, 2003 | 03:49 AM
  #195
fd1506's Avatar
fd1506
Keep em rollin
