Jim's ongoing starter issues.
A happy place to analyze the minutiae of starter engagement, ring gear depth, gear reduction vs direct drive, and other issues relating to my ability to eat starters like popcorn.
It started innocently enough...
With the bendix style starters the bearings would wear out or the whole snout would snap off.
The later PMGR style starters have just destroyed the gears I think.
I don't know how I'd shim something that has a concentric piloting diameter.
I suppose I could grind some of the lip away, and slot the lower screw hole to bring it away from the crank centerline a little bit.
This has been an ongoing issue with this flywheel/tranny combo and I wish I knew what to do about it.
I've tried different brands (Including Motorcraft) from different stores. Advanced, CarQuest, NAPA, Ebay, Ford Dealer.
The flywheel/ring gear is aftermarket Dorman brand for a 1994, 5 speed application.
It is what was immediately available when I discovered that my ZF clutch would not bolt to the flywheel I had for the T-19 that came in my truck.
Now, with the PMGR starters, the gear reduction is being broken.
The "bendix gear" looks fine in all cases...
How hard would it be to clean an area on the ring gear and paint it and the starter gear with layout dye, install the starter, give it a spin, and then check the starter gear? Then turn the engine by hand and inspect the ring gear's teeth.
I don't remember how that gear is installed on the shaft, but if it would come off I would think it could be machined a bit. If the depth of the starter's teeth are the problem, meaning that they are hitting the bottom of the ring gear's teeth, you could even do the machining in the lathe, but you would have to round them by hand after trimming them. And, if the depth isn't enough you could help that some on a mill with either a spin indexer or rotary table. However, you would surely void the warranty on the starter. Surely there is a better way..
I don't think the bearings would wear or the snout would break off if there was too little mesh.
I already have a PM in to Matt.
Again, that's not the best approach since you'd have to do it again if you had to replace the starter. And, it surely voids the warranty. But, it may be the only way to solve the problem.
I hope not. I hope Matt can help.
Anyway, I'll just read the mail and not confuse the situation. But, I do agree we need some kind of sticky on starters. As you know, I'm looking at a ZF5 swap and the starter is a question in that. So, it would be helpful if someone could write up what the various dimensions are, what causes them to be different, etc.
Anyway, both flywheels measure 15 9/16" in diameter and have the same tooth-count.
I have .557-.558" from the face of the dust plate to the face of the ring gear.
The starter gear projects .503" from the face of the starter.
The starter gear has .494" that it can throw outward.
Here's a look at the teeth of the starter:
Sorry for the photo quality.
The camera in my phone is marginal, and the lens cover is dirty.
I'll add that this is a BBB Industries brand starter intended for a manual transmission with a 10 tooth pinion gear.
DB Electrical - FORD STARTER F E TRUCK VAN 7.5L 460 92-97 336-1169 SA-795
NEW STARTER FORD E F SERIES VANS & PICKUPS | eBay
This is one of the brands recommended by Archion.
Yeah, I know it's Chinese...
So, now I have to find a rebuilt BBB starter...
I can't find the Delco 336-1169 except on Amazon.
There's ONE Wilson 91-02-5861 on Ebay.
As you can see there is a raised piloting diameter that fits in the hole of the dust shield.
my first .503" measurement is from the lower (but unmachined) face of the starter, not the raised lip.[/quote]
The as cast raised boss varies (obviously) but is about .180" .181-.178-.,,, well you get the idea.
The full height of the pinion gear is .690"
The depth below the machined clamping face, to the back of the gear is -.225"
The height above the machined face to the top of the gear is .465"
So, given that I have .557" from the clamping surface to the face of the ring gear, that's 112thou clear.
And since I have .494" throw, there should be more than 3/8" engagement. (.382")
What are your feelings about this?
I didn't forget what you said about end play in the crank. I'll try to get my wife to help with the clutch tomorrow.
I did rotate the crank one full revolution and saw no flat spots or missing teeth.
It's not easy to turn over with a 1/2" ratchet, so I'm afraid there's no way I'm going to see concentricity. (runout)
I have a couple of mag base indicators I could use and crawl back under to check the numbers every few degrees.
I'll do that after it warms up tomorrow.
When you say "breaks the snout off" . Do you mean the actual starter case where it is semi domed?
The snout projects quite a bit more for the flexplate.
The old "see-saw" style starters don't play well with the positioning of the ZF bellhousing, but are fine with the flexplate.
Yes, it snapped the whole dome off of the starter where the outboard bearing supports the bendix shaft.
Yes, it is the ring gear that's of concern Gary.
I would like to see if the plate is flat -and- if the ring gear is concentric with the crankshaft centerline.
This thing came as a unit (ring already mounted on flywheel)
It's a service replacement part, not like you would buy individually at the dealer.
I just can't be in a position to turn the crank AND watch the ring gear through the starter hole.
So, I suppose I need to just indicate it and check every few degrees.
I'm waiting for it to break 30* before I mess with the truck.
I have found that the bushing in the nose of my starter is loose to the point of falling out.
Tempted to just take it apart and try putting it back in with Loctite bearing retainer.
If I'm going to write this starter off I may as well experiment.
Think I'll slot the lower (unthreaded) bolt hole and also relieve the piloting diameter so I can change the depth of mesh.
I don't know if I have any layout paste around, but I could go to the drug store and get some zinc oxide...
{AT THIS POINT CHRIS (the moderator) MADE MENTION OF ALL THE BANDWIDTH WE WERE USING IN THE WHYDTYTT THREAD, AND I DID A BUNCH OF CUT AND PASTE TO START A THREAD ABOUT MY PROBLEM}
Bill (I think) suggested we may need a sticky about these issues. And, while I certainly agree we need a sticky written about flywheel/flexplate pairing with starters, I'm thinking we may need this conversation moved to its own thread so it actually could be followed at a future date.
TODAY, I pried and pulled on my crankshaft.
I had my wife step on the clutch.
There's only .0055" endplay.
I disassembled my starter and found the bushing in the front was ovaled.
The plastic gear housing looked fine;
I took a file and made some room to move it over by ovaling the unthreaded hole and thinning one wall of the boss;
Since it works fine out of the truck, and it started skipping before it finally got to the point where it was free spinning and not engaging at all, I am coming to the conclusion that there is not enough depth and the damage is being done because the teeth are camming out and over those of the ring gear.
I will try to see if it helps to move it closer to the centerline.
I would say a diameter issue and the teeth match is either to shallow or deep. I cannot see the depth well enough in the pictures.
Though it could be a tooth shape issue as well. Regardless, I suspect the ring gear.
-Enjoy
fh : )_~
so i needed the correct flexplate and starter combo.. i dont know if this helps but maybe just double check to see if you are certain you have the correct starter and flywheel/ flexplate combo.
I'm not sure you will get much adjustment by slotting the hole as the starter is aligned by the machined pilot. You might have to do the same to the clutch housing and block plate for the upper bolt to allow the starter to rotate since it is asymmetric in it's gear position. FWIW, my truck has several worn areas on the flexplate, and I have never had a problem, the original Ford starter lasted 20 years, and Matt got me this one at that time, so it's been on the truck for 6 years, granted I don't drive mine every day like you.
Do you think you could find a needle bearing that would fit and use it in place of the bushing? That might last longer.
If you are going to sacrifice this starter in the interest of finding the problem, bear with me because I've never had one of these apart, would it be feasible to take the drive and use a dummy shaft to allow a closer measurement of gear stroke and mesh with the nose casting bolted on?
I installed the starter closer to the crankshaft.
The starter which had been making noise and then was just freewheeling now starts the truck every time.
I don't know how long it will stay in that position since it is not supported from pivoting away, just held there by the clamping force of the lower bolt.
I did use fresh grade 5 bolts and blue Loctite.
It seems the reason the starters were wearing the bushing was because the engagement is too shallow.
The gears are climbing out of mesh.
I'm not sure if this is because of the tooth form on the ring gear, or that it's diameter is too small.
What I do know is that I need a starter that either has a larger diameter pinion gear or one that places the axis closer to the crank centerline.
Maybe Archion has access to manufacturing spec's or data sheets that could point me in the right direction?
While I had it gutted I set the nosecone up in place to see how things fit.
(no, I did not put the gear and shaft in place)
I decided that in order to be reversible I would only modify the starter.
I not only slotted the lower unthreaded bolt hole, I relieved the machined piloting diameter.
You can see in the above photos how thin the ring is on the open side of the case.
Could I go more?
I don't know, because I would run out of flange for the lower bolt to clamp.
And I edited out my quotes so it seemed more like a dialog than just a string of word balloons.
The ring gear teeth have a slight chamfer at the tip, but are not skewed like the starter.
I can try and get a picture with a better camera.
The iPhone 3Gs has no flash and is too stopped down to get a good pic in low light.
As I said, the flywheel assembly came with the ring gear mounted.
I think I can just cut a little block of aluminum to fill the empty section of old bolt hole so the starter cannot pivot back over, and out of engagement.
