Jim's ongoing starter issues.
Old Dec 28, 2013 | 06:58 PM
  #106
Gary Lewis's Avatar
Gary Lewis
True. But if you don't tilt the tranny a long ways down or pull on the TC then it will be seated. Just go slowly as you snug the bolts up and. If things start to get tight stop. Been there, done that, and didnt hurt a thing.
Old Dec 28, 2013 | 07:22 PM
  #107
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm assuming he just wants to pull the tranny back in order to swap the flexplate?
I've done clutches with the gearbox hanging on the crossmember.
So little room that I had to cut down the pilot tool.
Old Dec 28, 2013 | 07:40 PM
  #108
Ken Blythen's Avatar
Ken Blythen
I did something of a C6 step-by-step install post for a member about a year ago, if it helps (post #9 in the thread below).
My truck was auto previously (a couple of times.......& manual, also a couple of times )
https://www.ford-trucks.com/forums/1...l#post12673607
Old Dec 28, 2013 | 07:52 PM
  #109
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ken,
Do you have both a column shift and clutch pedal installed in your truck?
Old Dec 28, 2013 | 08:14 PM
  #110
Ken Blythen
I have right now Jim, although I took the shifter lever off the auto column, & swapped the dash shift guide (PRND21) for the manual dash piece.
I've got a complete manual, tilt column here that I'm going to go over, & then swap in to finish the job.
Old Dec 28, 2013 | 08:20 PM
  #111
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
When you pull the converter nuts off, two items, first use a 6 point socket, the hex on the nuts is shallow and a 12 point will round them to where they have to be cut off, second, after all 4 are off, push the converter as far back as it will go, then measure how far back the end of the studs are from the front of the converter housing. That way you wil be able to tell if it is seated correctly.
Old Dec 28, 2013 | 08:35 PM
  #112
Gary Lewis's Avatar
Gary Lewis
Good point. In theory he could slide the tranny back on long pilot pins, but not the bottom two, supporting the back of the tranny/t-case with a floor jack, and change out the flex plate. (You wouldn't use the bottom bolt holes as you probably can't get the flex plate out if you do.) That would side-step the problem of balancing the tranny/t-case on a jack since the guide pins would keep it from twisting.
And, Bill is absolutely correct. Do not use a 12 point socket! Nor open-end wrenches.
Old Dec 28, 2013 | 08:40 PM
  #113
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wouldn't even need to be pins, Gary.
Two 4-5" 7/16-14 bolts would be fine, and the bell couldn't slip off the back.
(I don't really know how much room is in the tunnel)
Old Dec 28, 2013 | 08:44 PM
  #114
CarolinaCanes's Avatar
CarolinaCanes
Nice tip. I will be sure to remember that. Measuring the converter depth sounds like a good way to ensure it seated. I'm not taking it out so I wasn't sure how I would know for sure.
Old Dec 28, 2013 | 08:48 PM
  #115
Gary Lewis's Avatar
Gary Lewis
Very true. There's enough room to get the tranny's input shaft out of the torque converter as I've done that. And, you can remove the fan so you can drop the back of the tranny, tilting the engine up, to get a bit more room if needed.
Old Dec 28, 2013 | 08:52 PM
  #116
CarolinaCanes
Basically make the screw in pilot screws as mentioned above, but longer and replacing the bolts that connect the tranny and engine with these? That sounds like it would take a lot of the chance for error out. Ie tipping the tranny forward and dislodging TQ as well as any twisting. That is an awesome idea.
How long do you think I could make these pilot pins without them bending?
Old Dec 28, 2013 | 08:59 PM
  #117
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You don't need to make pins.
You don't need to slip the bell back onto them.
A wrench is easier than a screwdriver up towards the top.
Buy grade 8 bolts and the block will snap before you bend two 7/16 bolts.
Old Dec 28, 2013 | 09:12 PM
  #118
Gary Lewis's Avatar
Gary Lewis
Yep. I would go under and measure to see how long of bolt you can get in. And each location will Cary as up at the top won't take a long bolt. And, as said, with several bolts in you can use the weight of the tranny/t-case combo to tilt the engine back to give more clearance. But you will have to remove the rear crossmember if you want to tilt the engine. And once it is tilted you can put a jack with a block of wood under the crank pulley to keep it there when you slide the tranny back.
Old May 10, 2014 | 06:52 PM
  #119
bullnose1985's Avatar
bullnose1985
[B/]I hope this is helpful it made a world of difference for my starter eater. I am running a 460 with a T19 4 spd. The truck used to be a 6.9 diesel before the previous owner swapped it for a 460 7.5.
The above picture I think are the starters for a 351 automatic and the other is for a standard. I didn't look at my old one I just put it in the box as a core and sent it on its way. The one on the left was my first and second replacement and the one on the right is the one that I have been using for about 3 months.
[/B]
Old Jun 24, 2014 | 10:48 AM
  #120
bullnose1985
Angry
well I stand corrected again. Just put a 3rd starter on my truck. I am still using the manual transmission starter.
On a related issue. On a blue stress relief duraspark II ingnition doesn't the white wire connect some where to the starter circuit? To retard the timing to ease stress on the starter?? If so dose anyone know where?
