Coleman lantern
Old Jan 7, 2015 | 10:19 PM
  #436
wpnaes's Avatar
wpnaes
Originally Posted by Tedster9
Yeah, i read that... before I dived into it. Try as I might I was unable to install the generator and install the hook end into the hole without lifting the cage out. No idea why, there just isn't clearance. Both washers are installed. I didn't break it down much farther than that, just tightened all the fittings up a smidge.
You're right, the cage needs to come off a 200A. The 220 genny's can be slid into the air tube for removal/replacement.
Originally Posted by SpringerPop
Fresh-Water-Reed Basket Weavers Monthly doesn't seem to be around any more...........
Pop
We're gonna need to see a photo of that...
Old Jan 7, 2015 | 10:36 PM
  #437
Tedster9's Avatar
Tedster9
I don't think the generator was installed correctly because I was able to remove it without removing the cage, although it probably doesn't matter. Maybe the cleaning needle wasn't doing its job. I had to do open lantern surgery and straighten it out carefully. Works OK now.
Old Jan 7, 2015 | 10:46 PM
  #438
OldBlackCat's Avatar
OldBlackCat
Originally Posted by wpnaes
You know about burning them out, then pick out the ash?
just to add on a tidbit of info to seans great pictures! just be careful when heating them up!the insert is brass and it don't take much to melt them... i learned that the hard way
Old Jan 17, 2015 | 09:40 AM
  #439
wpnaes's Avatar
wpnaes
I see another Frankie for sale on Epay, giving me ideas...
Old Feb 11, 2015 | 12:17 AM
  #440
OldBlackCat
1975 Coleman Milspec i picked up over the weekend...
tinkered with it tonight a little bit.... stepped up to the plate and got a flame ball (strike one)...hmm ok will clean the air tubes.... after a bunch of brake cleaner and 140psi of air, i forgot about the plug blocking the one air tube (factory) and shot the plug across the garage and now is MIA (strike two) so i stuffed a 3/8" bolt in the tube.... put the lantern back togeather new mantle and lit it up! (SWING! its going deeep left field!!!)...but i did not got a money shot of it running tonight (pop fly.... strike three)
haha anyways here is a couple pictures.
Old Feb 11, 2015 | 07:48 AM
  #441
wpnaes's Avatar
wpnaes
Nice Justin, I need to get the cob webs outta mine. Looks like It has the heavy glass quadrants and captured funnel. Don't see the tools that go by the genny.
Old Feb 12, 2015 | 12:32 AM
  #442
OldBlackCat
the wrench for the genny that also has a little pricker on it is inside the parts well... far as im aware thats its home... but im a newb to the milspecs.
Old Feb 22, 2015 | 01:50 PM
  #443
OldBlackCat
Good seeing you sean and others! at the SoCal Breakfast G2G!
sean, you were asking me about the snap hooks i was using for my lanterns. so i snapped a couple pictures. the part numbers on the hardware are for lowes, but the snap hook is 1/4" size which is rated for 80lbs! no particular reason i got that size, just cause its the smallest i could find.
Old Feb 22, 2015 | 02:00 PM
  #444
SpringerPop's Avatar
SpringerPop
A pair of those little snap hooks are what I use to attach the break-away cable to my frame when towing. Carabiners are what I envisioned when you were talking about these.
Good light-up for you this morning!
Pop
Old Feb 22, 2015 | 02:03 PM
  #445
OldBlackCat
Pop
yeah, everyone has different terms for the little buggers....
there a little pricey at lowes, couple bucks a pop for the ones i got. a quick google search i found them for .40 cents.
Old Feb 22, 2015 | 05:27 PM
  #446
wpnaes's Avatar
wpnaes
Old Feb 23, 2015 | 12:26 AM
  #447
OldBlackCat
any of those should work! when i was building my first shelf lowes didn't have a nice selection of tea cup hooks. soo i went Tim Allen and went overboard !
Old Apr 6, 2015 | 01:18 AM
  #448
wpnaes's Avatar
wpnaes
Time for an update.
A few old pics to keep this thread alive!
Old May 25, 2015 | 09:52 AM
  #449
wpnaes's Avatar
wpnaes
Light one today as a memorial to those who gave their lives.
Old May 25, 2015 | 10:38 AM
  #450
SpringerPop
Good reminder!
Will do!
Pop
