Remote start
Old Sep 12, 2011 | 04:02 PM
  #136
MNDiesel2's Avatar
MNDiesel2
Looks like they are the same with the exception of the security system. Could check the Ford site and see what that says.....
Gotta swing by my remote start guy and see what he says for install .... if I have to buy a bunch of extra stuff I'm just going to go with the Ford one for $250....seems like a good price..
Old Sep 12, 2011 | 09:57 PM
  #137
PowerStrokeHD's Avatar
PowerStrokeHD
Originally Posted by Beach_Bob
Thanks for the clarification. Do the 100 series and the 200 series have the same range?
Correct... Series 100 and 200 are the same when it comes to the remote start portion. The Series 200 just adds the vehicle securtiy portion...
Old Jul 11, 2012 | 08:34 AM
  #138
sgrol's Avatar
sgrol
Old thread, I know. Have 2012 Job 2 and got the remote start to keep the truck running with the quick flip method described above. Worked about 2 of 8 times and I will need more practice to perfect it. Great trick - Thanks to the discoverers of this. Truck ran on for the programmed 5 minutes and then cut off. Had to remove all keys and key ring from key to get clean flip to off position.
Old Jul 11, 2012 | 09:06 AM
  #139
jdadamsjr's Avatar
jdadamsjr
Thanks for reviving as I have always liked that feature...
When it's 100+ here and I'm stopping for only a moment, don't want the air to go off for even a second
but couldn't get it to work for my 2012 Lariat ultimate...
Will read more in the manual...
Page 86 says:
REMOTE START CLIMATE OPERATION (IF EQUIPPED)
The climate control system will condition the cabin temperature during
remote start based on the outside temperature. Engine idle may increase
to help with adjusting the cabin temperature.
Note: No climate control adjustments will be recognized during remote
start operation and none of the climate function indicators will be
illuminated while the vehicle is in remote start. Once the ignition is
cycled to the on position, the climate control system will return to the
previous settings (last ignition-on cycle) and adjustments can be made
normally. If the previous setting was off, the climate control system will
turn off.
If you previously had any of the following activated: heated seats (if
equipped), cooled seats (if equipped), heated mirrors (if equipped), or
rear defrost, they will not return to their previous settings (on) when the
ignition is turned on and will need to be re-activated if desired.
For more information on remote start climate settings and options, refer
to Message Center in the Instrument Cluster chapter.
Page 134 says:
Using MyKey with remote start systems
MyKey is not compatible with non Ford-approved aftermarket remote
start systems. If you choose to install a remote start system please see
your authorized dealer for a Ford approved remote start system.
Page 10 of the diesel supplement says:
STOPPING THE ENGINE
Turn the ignition to the off position.
To prolong engine life (especially after extended high speed, high
ambient temperature, or high GVW/GCW operation, such as heavy loads
and/or heavy trailers), it is recommended that a hot engine be idled for
3-5 minutes which will allow the turbocharged engine to cool down. For
more information on GVW/GCW, see Vehicle loading – with and
without a trailer in the Owner guide
Old Jul 11, 2012 | 09:07 AM
  #140
jdadamsjr's Avatar
jdadamsjr
And what is this ?!?!
Many states and provinces have restrictions for the use of remote start.
Check your local and state or provincial laws for specific requirements
regarding remote start systems.
Really ? Why ? is it the tree huggers or ?!?
I know once an Arlington, Tx cop gave me grief as I was walking out the mall saying I couldn't leave my Excursion running...
but he thought I had left the keys in it Dooh, nope - remote started it as I was walking out !
He apologized ! A good natured leo is nice - don't envy them their job at all !
Old Jul 11, 2012 | 09:41 AM
  #141
sgrol's Avatar
sgrol
You obviously won't find the trick in the manual and FWIW, I don't have any Mykeys programmed in. See post #98. Only difference I found is that you don't have to quickly remove the key, just quickly turn to off position. Truck will hesitate and then keep running. All dash lights and guages went off and Nav stayed on until I opened the door. Got out relocked and walked away. Truck shut off after 5 minutes (I have 5 min programmed in for remote start duration). Like I said, you have to be fast and it did not work for me every time.
Old Jul 11, 2012 | 10:03 AM
  #142
jdadamsjr's Avatar
jdadamsjr
Ah, ok - my Ex's ford gold remote was more forgiving I guess not as quick as I used to be !
Old Jul 15, 2012 | 10:29 PM
  #143
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
If i need to leave it running i just leave the key in and lock the doors. With such dark windows its impossible to see if the keys are in it or if anyone is inside...
Old Jul 16, 2012 | 08:38 AM
  #144
bama29fan's Avatar
bama29fan
same here....use the key pad on the door to get back in.
Old Jul 16, 2012 | 08:52 AM
  #145
Tuxedo Scorpion
...and to lock the doors on the way out..
Old Jul 16, 2012 | 09:46 AM
  #146
bama29fan's Avatar
bama29fan
i havent used it to lock them yet.
when i pull in (to a gas station or where ever) i dont use the automatic door unlocks...i squeeze the door handle which only unlocks the driver side. then i manually push the drivers side door lock down to lock it and shut the door.
Old Jul 16, 2012 | 09:49 AM
  #147
Tuxedo Scorpion
Just push the last two buttons on the key pad
Old Jul 16, 2012 | 10:17 AM
  #148
bama29fan's Avatar
bama29fan
i'll try that....thanks.
Old Jul 16, 2012 | 04:24 PM
  #149
GDAWG 2012XLT's Avatar
GDAWG 2012XLT
I have a 11/11 build and I hit lock once and RS 2 times door closed and exit truck. Truck run for 5 min and shut off. Tride it the same way but with the door open and it worked fine. I even tried it without dirving and it works.
shortride
Jun 6, 2017 08:56 PM
redz284u
Dec 19, 2016 02:42 PM
treatcg
6.7L Power Stroke Diesel
Dec 13, 2016 10:57 AM
Rob89
Sep 6, 2016 01:34 PM
Lastwagen
20
Jan 4, 2016 10:57 AM
