Remote start
Old Jul 23, 2011 | 10:30 AM
  #76
Davgt500's Avatar
Davgt500
Originally Posted by my996duc1
What is the "Limited Edition" seats ?
I've seen them mentioned before but not sure what they are....
Here is a picture of mine
https://www.ford-trucks.com/forums/p...ictureid=75321
Old Jul 23, 2011 | 11:25 AM
  #77
mhoefer's Avatar
mhoefer
Ok, so, I am not saying this doubting you guys, but icant help think the sequence of steps is not being done correctly to get the necessary results. My remote start has several sequences for temp sensitive start, extending run time, things like that and it's really tricky to do the correct sequences. granted it's aftermarket, but, it's likely similar programming. so, things like foot off brake, two pushes of start button? How far apart each of the two pushes are, do they make the same tone, beep? Mine has two types.... Short poke single beep, versus double short with a longer beep. Which are you doing with key on, foot off brake. This seems to be a simple programming type issue where the steps are not eas to follow reliably.
Old Jul 23, 2011 | 04:57 PM
  #78
lkbrow1's Avatar
lkbrow1
Maybe it is configurable with a tool that plugs into the connector under the dash. I tried it on my truck and it did not work either. Built 4/30/11.
Old Jul 23, 2011 | 05:34 PM
  #79
srkr's Avatar
srkr
Originally Posted by kper05
The "limited edition" name was coined by members here.
These are the two-tone leather seats that Ford offered for a few months with the job 1 trucks last year.
My ears were burning....
Ohhh You mean THE "Limited Edition" Seat!!!
Shane
Old Jul 23, 2011 | 05:45 PM
  #80
720Deere's Avatar
720Deere
Dude somebody spilled coffee all over your seats! Oh yeah they are supposed to look like that aren't they?
Old Jul 23, 2011 | 05:52 PM
  #81
Pacman51's Avatar
Pacman51
I looked at a truck with those seats and turned it down because of them.....to me they are just downright fugly.
Old Jul 23, 2011 | 05:56 PM
  #82
srkr's Avatar
srkr
Jealousy rears it's UGLY head again.....
BTW, back on topic, I tried the after RS and my Job 1 does not work either. I have the current TSB.
Shane
Old Jul 23, 2011 | 06:07 PM
  #83
my996duc1's Avatar
my996duc1
Originally Posted by Davgt500
hummm, I have the "limited edition" seats and didn't even know it.
I figured all seats were the same...
Heck seats are different, RS programming is different..... what else is "special" about this truck.
Gotta be more than two of us out there that can get the RS thing to work.
Old Jul 23, 2011 | 06:24 PM
  #84
srkr's Avatar
srkr
I'm thinking if, you have the IDLE mod from the factory ,CA. then it will work...otherwise,nope.
I'm guessing
Shane
Old Jul 23, 2011 | 06:37 PM
  #85
Davgt500's Avatar
Davgt500
Shane
Shane, The tan definitely looks sweeter than the charcoal limiteds that I have!
Old Jul 23, 2011 | 06:50 PM
  #86
Pacman51's Avatar
Pacman51
No, not so much......
Old Jul 23, 2011 | 08:54 PM
  #87
my996duc1's Avatar
my996duc1
I'm guessing
Shane
not sure I am following you...
the only idle mod I have is the SEIC that I did myself based on the info in the Tech Folder.
Old Jul 23, 2011 | 09:12 PM
  #88
russcue1's Avatar
russcue1
Thats the first time I have seen those seats...I like them...
Old Jul 23, 2011 | 09:32 PM
  #89
KC8QVO's Avatar
KC8QVO
Wow. I just read all the way through this thread start to finish. I could have been more efficient if I passed up all the limited edition seat talk Although, I did ride along in Rickatic's truck back in January and those are pretty nice seats!
As to the thread topic - remote start:
1. My remote start only works about half of the time. I think it is just a range issue, but I don't know. What is this "range booster" you guys are speaking of? Is it a Ford addition or is this third-party? I had an after-market remote start installed in my 2010 F-250 with the 6.4 and it worked a LOT better than my factory one does in my '11.
2. The feature allowing the engine to run when you remove the key is a pretty slick idea. I can't run out right now and try this. I have a King Ranch with nav and MyKey, the only functional option I don't have is a moon roof. It is also a Job 2. When I get out tomorrow I will check this feature out and see if I can get the original button sequence to work after the gear shifting.
3. Has anyone tried leaving out the lock button in the sequence? IE - just skipping right to the two hits of the circle button? I agree with the one guy that posted about there being different button sequences for programming whatever feature you want to get to run. My dad's Lexus will drop all the windows even with a button sequence.
4. High-Idle - I meant to do this on my 6.4 too. I will have to hook this up. There was talk about the high idle shutting off when the truck goes back in to remote start mode with all the screens blank. If the upfitter switches are run through the accessory on somehow, activated with a relay or run directly off the accessory power, then it WILL shut off with the accessory power off. That having been said, if the power is separate from the accessory on (IE - you can turn your accessories on and off with no key in the truck) then the circuitry for the high idle must have something to do with having the key in the ON position and theres no way around it.
I pulled out my upfitters and installed my own switch panel with some jacks on it for my ham radio installation. The power for everything is straight off the secondary battery. Depending on how the wire is hooked up for the high idle (+12v or switching to ground) I may be able to use one of the switches on my panel. They have constant power from the battery, no disconnect with the key out.
Old Jul 24, 2011 | 12:23 AM
  #90
Marauder92V's Avatar
Marauder92V
On your item 1 question: you can buy an accessory kit from Ford that extends the range of the remote start. I installed series 100 of this kit and I understand a series 200 kit is available that gives you some additional features. You can find details on it if you search "extended remote start" (I will see if I can find it). I routinely get 800 feet or more range using it. It is bidirectional.
