Remote start
Old Jul 26, 2011 | 06:53 AM
  #106
Pacman51's Avatar
Pacman51
Job 2 no go.
Old Jul 26, 2011 | 07:58 AM
  #107
6.7Fan's Avatar
6.7Fan
Originally Posted by Marauder92V
Ah, my friend, that is indeed the question to ask. Not sure which of the control modules are involved in your LECD function, but if it gets updated, I suspect there is a chance you will have the "NECD" (Non -Existent Cool Down)
I just recently (2 weeks ago) had the new trans flash and the daytime running lights turned on. I'm up to date on all flashes and luckily, it works on mine.
I wish I knew if it worked before the transmission flash. For those that it's working, have you had the trans flash?
Old Jul 26, 2011 | 08:18 AM
  #108
KenLaffin's Avatar
KenLaffin
It still don't work on mine.
Old Jul 26, 2011 | 09:01 AM
  #109
KenLaffin's Avatar
KenLaffin
Well I tried it again and IT WORKS. It's all Timing.
Old Jul 26, 2011 | 10:25 AM
  #110
mhoefer's Avatar
mhoefer
That a boy cabindoc. It's tricky but that's the way these are. My remote, all I dois push start with vehicle running, get out and lock. It's all in the technique. I bet if you read your remote manual there is also a way to extend idle time, temp protect (start below a certain temp).
Old Jul 26, 2011 | 06:15 PM
  #111
wharrell's Avatar
wharrell
I was just able to get mine to work on a March 2011 Build F350.
1. Door was already locked
2. Pushed remote lock button once
3. Pushed remote '2x' button twice
4. QUICKLY removed key, truck did not shut off
5. Opened door, truck did not shut off
6. Closed door with me inside, truck did not shut off
I did not leave the truck running long enough without the key to see if it would auto shut down after the 5' value in my settings.
Will try again for end to end test
Old Jul 26, 2011 | 06:59 PM
  #112
wharrell's Avatar
wharrell
Tried again and waited to see if truck would shut down at end of the setting value in the settings.
It did.
The important step appears to quickly turn the ignition off and remove key before the horn beeps
Old Jul 26, 2011 | 08:18 PM
  #113
2000silverbullet's Avatar
2000silverbullet
So it's working on the job 2's as well, nice! That's it, I'm purposely missing the shuttle to work tomorrow so I can mess around with it for 20 mins or while I'm waiting for the next one!
Old Jul 26, 2011 | 08:32 PM
  #114
srkr's Avatar
srkr
It did.
Do you HAVE to remove the key???
I'm gonna find out tomorrow,,..got a stomach bug.
Shane
Old Jul 26, 2011 | 08:41 PM
  #115
wharrell's Avatar
wharrell
Shane
I quickly turned the ignition off and removed the key.
I did not try it by just quickly turning the ignition off, but since the logic is to get the ignition switch turned off BEFORE the horn beeps, my hunch is leaving the key in will work.
Will try tomorrow.
Old Jul 26, 2011 | 08:58 PM
  #116
cabindoc's Avatar
cabindoc
Yes, I am all up to date on flashes, nox sensor issues, TSB's and trans flashes. PS, I have my shut off set at 5 min and it does shut down. I also have my autolock and autounlock turned on, but I dont think it makes a difference.
Someone should try leaving your thumb on the button while removing the key see if that makes the time less critical.
Old Jul 26, 2011 | 09:12 PM
  #117
my996duc1's Avatar
my996duc1
Shane
Seems to be alot of different variables between trucks....
On mine I do NOT have to remove the key and I do not need to count/time the button pushes, (you can see it in my videos), but my truck seems to be odd in that it also keeps the radio on until I open the door.
Be interesting to see all the different variables to get this to work between trucks.
Old Jul 26, 2011 | 11:09 PM
  #118
Dr. T's Avatar
Dr. T
Got it to work once on mine. 3/11 build.
Old Jul 27, 2011 | 03:37 PM
  #119
wharrell's Avatar
wharrell
Shane
Do not have to remove the key
Old Jul 27, 2011 | 05:00 PM
  #120
Dr. T's Avatar
Dr. T
Cool. Gotta work on the timing.
