Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Mar 28, 2014 | 07:53 PM
  #166
BADDBOYY21's Avatar
BADDBOYY21
Seems to me you asked for parts for a 1970 F750: Front fenders, inner fenders and a radiator support. You didn't mention your location, but I knew it was PA, cuz I looked at your profile.
Only a few of each of these parts were available, so...I listed what I could find...and where.
Dash pad in any color will be very hard to find, all are obsolete, AFAIK, not reproduced. I'll take a look-see for these other parts later today.
Yes, I did. I did not end up buying the 1970 due to the availability of parts.
Old Apr 2, 2014 | 07:59 PM
  #167
rollinblacksmoke's Avatar
rollinblacksmoke
VIN decoding?
Can someone decode my vin please? it is : U911VU52928 Thank you!!!
Old Apr 2, 2014 | 09:07 PM
  #168
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Hi Bill,
I'm looking for a tail gate reflector to a 2002 Lincoln Blackwood, passenger side.
Part # is 2C6Z-13A565-AA (or AB) but I'm not sure which is left or right. I need the passenger side.
I know the part is obsoleted. I'm trying to find dusty old stock somewhere.
Thanks for being here for us!
Old Apr 2, 2014 | 10:14 PM
  #169
Mass Transit's Avatar
Mass Transit
F600 VIN Decode
I just bought a 1978 F600 Custom Cab dump truck with power steering and chrome grille. I'm interested in finding information from the data tag:
F61DCT27331
WB: 134
Color: T
Type: F611
Body: B8
Trans: 8
Axle: F31
Max GVW: 20200
D.S.O.: 11
Also, any idea where I can get the factory red vinyl & vinyl-weave bench seat material?
Thanks!
Old Apr 2, 2014 | 10:56 PM
  #170
FordMan1965's Avatar
FordMan1965
Just got a dump truck given to me....
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Hello everyone, I have been a member since 2009 but have not been active. I was just given a truck(dump) but need help in deciphering the VIN... Hope you can help. Here is it: N70EVU11473
Thanks and as soon as I get her home I will upload some pics... she has been in "barn storage".
Old Apr 4, 2014 | 08:54 AM
  #171
lawverdict's Avatar
lawverdict
vin decode request.
Serial No.: F60V6U64124
Color: S
Rear axle: 6.8
Production code: 14J741005P
GVW: 17000
D.S.O: 740001
Any information regarding the above is appreciated.
Mike
Old Apr 4, 2014 | 11:43 AM
  #172
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I don't have a parts catalog after 2001, so I don't know which is the right (passenger) side. Usually the right side (AA) is listed first, but...
No FoMoCo dealer or obsolete parts vendor has either side.
Old Apr 4, 2014 | 11:51 AM
  #173
NumberDummy
Originally Posted by rollinblacksmoke
Can someone decode my vin please? U911VU52928
U91 = LT900 diesel.
1 = Cummins NH230 855 cid 6 cylinder diesel.
V = Kentucky Truck Assembly Plant.
U52928 = This is either a 1974 or 1975.
Old Apr 4, 2014 | 12:30 PM
  #174
rollinblacksmoke
Thanks for the info Numberdummy, the truck is titled and was sold to me as a 1975 model. I used it for a few years, and sadly parked about 2-3 years ago. I have plans to revive it and put it back into service. It is a dump truck and is a BEAST!!!! I love and can't wait to get back on it. Thanks again for the info.
Old Apr 4, 2014 | 12:36 PM
  #175
rollinblacksmoke
Other info on vin tag is:
W.B. 204
Color: BS
Type/G.V.W.: U914
Body: AE8
Trans.: J
Axle: D8P
Max G.V.W. LBS: 44800
DSO: 250623
Thank you for sharing your knowledge!!!
Old Apr 4, 2014 | 02:51 PM
  #176
NumberDummy
Other info on Warranty Plate: W.B. 204 / Color: BS / Type/GVW: U914 / Body: AE8 / Trans: J / Axle: D8P / Max G.V.W. LBS: 44800 / DSO: 250623
204" Wheelbase.
BS: B = Light Blue / S = Bright Dark Blue Metallic.
U914 = LT900 (diesel), 44,800 lbs. GVWR
AE8: AE = Medium Gray Vinyl / 8 = Standard or Custom Cab without Butterfly Hood.
J = Fuller model RTO-9513 13 Speed Overdrive.
D8P:
D8 = Rockwell-Timken model SQHD Rear Axle w/Hendrickson Suspension / 4.88-1 / 38,000 lbs. Rear Axle Capacity.
P = Rockwell-Timken model FF-903 Front Axle with Power Steering / 12,000 lbs. Front Axle Capacity.
44,800 lbs. Gross Vehicle Weight Rating.
250623:
25 = Richmond VA Ford District Sales Office, where the original selling dealer ordered the truck from.
0623 = Domestic Special Order number: Your truck was ordered special by the original purchaser, not "bought off the lot."
Old Apr 4, 2014 | 06:45 PM
  #177
rollinblacksmoke
WOW!!!!!!!!!! You SIR are a Ford Encyclopedia!!!!! Thank you again for the information. Very interesting!!!!
Old Apr 4, 2014 | 06:58 PM
  #178
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Thanks for checking for me, Bill! Sort of what I expected, and not what I wanted to hear, but I do appreciate you looking into it all the same.
Old Apr 5, 2014 | 12:59 AM
  #179
NumberDummy
Originally Posted by Mass Transit
I just bought a 1978 F600 Custom Cab dump truck with power steering and chrome grille. I'm interested in finding information from the Warranty Plate:
F61DCT27331 / WB: 134 / Color: T / Type: F611 / Body: B8 / Trans: 8 / Axle: F31 / Max GVW: 20200 / DSO: 11
smsautofabrics.com - located in Canby Oregon
Something smells and it ain't hay.This VIN and Warranty Plate codes do not match a 1978 F600 Custom Cab with a red interior
The last 6 digits of the VIN (T27331) decodes to a 1974 F600 2WD / 1974 serial number range: S60,001-U80,000 / 1978 serial number range: AA5,001-CJ5,000.
1974 BODY code B8: B = Medium Blue Vinyl / 8 = Custom Cab.
There is no parts catalog reference for a 1974 F500/880 or 1978 F600/880 with the type of upholstery you have described. It's possible the seat is from a 1973/79 F100/350 Ranger.
*Compare the VIN on the Warranty Plate to the VIN on the registration/title to see if they match. Warranty Plate riveted to the left door face below the latch.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Old Apr 7, 2014 | 10:19 PM
  #180
Mass Transit
I should have checked the registration first. It's listed as a 1974 and the vin on the tag matches the registration. Maybe the body code is E8?
