issues getting engine swap to run, help.
Old Mar 25, 2011 | 10:34 PM
  #91
49fordpickumup's Avatar
49fordpickumup
I'm beginning to think since it starts already, grounding pin 30 may not produce any differance since there isn't a computer to operate the sensors and if the distributor has a electrical module attached to the side it will need the computer to operate the distributor. Maybe that is why it is backfiring, etc. Also a TV cable disconnected or not adjusted could ruin the tranmission quickly. It might be cheaper to find another 1988 Tbird on cragslist to get the missing parts. I bought a 1995 tbird last year, took off what I wanted and resold the engine./tranny and then the car. Ended up cheap parts. chuck
Old Mar 25, 2011 | 10:36 PM
  #92
Jeff and Nicolle's Avatar
Jeff and Nicolle
Originally Posted by 49fordpickumup
Latest goggle find. (1) Fuel min of 35 PSI.
(2) AOD non-elect until 1993
(3) EEC-IV distributor has a electric sensor in/on Dist.
(4) Has a TV cable to adjust.
(5) Having some sensors to fail has a limp home mode.
(6) Needs the computer. Also attaches to the back of the speedometer.
(7) For a transplant it recommended a prior 1988 engine.
(8) Neu safety provides a ground for MAP and also TPS along with a N or P start function.
Chuck
Hemmings Motor News: Ford AOD Overdrive Transmission
Hey Chuck thats an interesting find! #8
Joe and email crasher that might be something! if that MAP sensor doesn't
have a completed circuit then it would work right or at all, could cause that backfiring maybe? but then you never had a malfunction code on that so maybe not...
Old Mar 25, 2011 | 10:38 PM
  #93
carnut122's Avatar
carnut122
Originally Posted by Jeff and Nicolle
carnutt take as much credit as anyone else! there is no "I" in "TEAM"
that's how I like it ! you were looking listening and its all about helping or getting help! And that little red '53 is looking real sweet! looking forward to more pics! I wish I had a building like that!
Jeff, Great response! I just like it when I "get a hit." Keep after this as I'm hoping to fire mine up this summer. I'll bookmark this thread so that I can refer back to it if I need to. The building was my 25th anniversary present. I just can't wait to get the truck finished so that I can get rid of the extra parts and park my Fiero on the other side.
Old Mar 25, 2011 | 10:41 PM
  #94
carnut122's Avatar
carnut122
Here's a link for the throttle valve adjustment. Don't burn up your tranny by overlooking this.
YouTube - Ford AOD TV cable adjustment
Old Mar 25, 2011 | 10:59 PM
  #95
Jeff and Nicolle
Chuck I think you misread something there...The tranny has no sensors that connect to the computer, but the sensors on the engine are connected to the computer...
That is a great article on the AOD transmission though, I bookmarked that one!
carnutt a FIERO ??? must enjoy go karts huh?
I never owned one, but I did do alot of maintenance on one for a friend...man I hated workin on that thing...mid engine lower back KILLER !!
It was a fun car to drive in the hairpin turns though!
Old Mar 25, 2011 | 11:12 PM
  #96
Email crasher's Avatar
Email crasher
after grounding out the 30 pin wire, i checked the codes and all we have is 81, 82, and 87. NO 67.
BUT, the motor will start and run for about 2 seconds and then die. even if i give it gas.
i disconnected the battery and im gonna go out there again and check it out again.
Old Mar 25, 2011 | 11:29 PM
  #97
Email crasher
here's something to give you an idea of what we are working with.
heres the one and only wire coming from the tranny, 4 wires in one plug
Old Mar 25, 2011 | 11:32 PM
  #98
Jeff and Nicolle
Man I don't know what to say...except that something isn't connected right with that setup. when that harness got cut up it's impossible for me to know what the heck is goin on. obviously grounding that pin 30 isn't correct. I have seen many pinout diagrams and they all show pin 30 grounded...i think. I don't want to keep throwin you guys into wild goose chases anymore...I feel bad about this, but I am just as frustrated as you guys now!
Old Mar 25, 2011 | 11:43 PM
  #99
Email crasher
its a goose chase alright LOL but we have to do it or it wont get fixed. you feeding us this info it FREAKIN GREAT. dont get me wrong.
I have "All data" on my computer so it helps a lot. i have given up for the night.
its hard working on cars all day at a shop and then coming home to this LOL
Old Mar 26, 2011 | 12:02 AM
  #100
Jeff and Nicolle
http://fordfuelinjection.com/files/EFI_harness4.gif i think I post this before but again its a good reference to the 88 you are workin with.
i wish you had an uncut harness just to rule out that problem or at least had a good one to compare connections. i will check back tomorrow.
I told joe and will mention again, FordFueInjection.com is a good source of info on this stuff. most of what I have thrown out here (the links) are from there.you may want to search there.
I have seen that ALL DATA looks helpful, do you like it?
ok guys im out for tonight...
yeah I understand...burnout mode...work at work and work at home...
Old Mar 26, 2011 | 11:27 AM
  #101
Jeff and Nicolle
this diagram tells me that pin 30 is NOT supposed to be grounded...but it would be 12 volt from the neutral safety switch.
will someone else verify this? I am not an electrical guy per say...
Old Mar 26, 2011 | 11:29 AM
  #102
Jeff and Nicolle
May have to save the image to your computer because I tried to zoom in on it here and it gets real blurry, but i can email my original to whoever if needed.
Old Mar 27, 2011 | 12:15 AM
  #103
49fordpickumup
Old Mar 27, 2011 | 12:24 AM
  #104
49fordpickumup
Jeff, check this . It came from your previous post. Wires from the TPS and MAP go to 30 and to ground. So it does more than just the Neu safety swirch but how it is affecting the MAP and TPS without a computer I don't know. The article I found said the distributor has a electronic module attached to the side of the dist. I said in previous post no computer for the AOD. Maybe I wasn't very clear the way I wrote it. chuck
Old Mar 27, 2011 | 09:29 AM
  #105
Jeff and Nicolle
hi Chuck, yes you are correct. I did misunderstand you. yeah the AOD is not controlled by a computer. now as for the pin 30 ordeal....i am still researching all of that. I am assuming that it has to do with engine load when in gear vs park/neutral. just haven't found the answers yet.
