issues getting engine swap to run, help.
Old Mar 23, 2011 | 11:37 PM
  #76
49fordpickumup's Avatar
49fordpickumup
I found one short article about the safety switch. Without the computer, they did use the safety switch. There are only two wires to use so if they are now touching and you have the problem, open the two wires. In other words do the opposite from what they are now to test your drive function. We don't know if it affect the run if the wires are not correct along witht he P and n start function. Easy test. Maybe nothing. but???
chuck
Old Mar 24, 2011 | 01:53 PM
  #77
Jeff and Nicolle's Avatar
Jeff and Nicolle
Joe did you get anywhere with that? last night?
Old Mar 24, 2011 | 02:11 PM
  #78
jburroughs12's Avatar
jburroughs12
I got nowhere with it. We got to thinking about it. The computer doesn't know whether its in park or drive. The transmission mounted safety switch isn't hooked up to anything. So I don't necessarily think its the neutral safety switch, but the fact that the ecm isn't getting a signal.
Old Mar 24, 2011 | 02:56 PM
  #79
Jeff and Nicolle
ok just checking. without being there and being part of the installation and such, it's just tough to know what ya got goin on there. i wish I was able to help ya more, but...maybe the guys on your other link might chime in...i will keep thinkin and watchin this thread, if I come up with any other possibilities i will jump in. keep us posted Joe..
Old Mar 24, 2011 | 03:01 PM
  #80
Jeff and Nicolle
Proof a code 67 causes idle problems
there is a video that you should watch here.
Old Mar 24, 2011 | 04:40 PM
  #81
jburroughs12
Alright, I'll definitely have to look into the neutral safety switch issue. Now I just have to labor over my wiring diagrams to find out what wires I need to jumper;, since the interior harness was just cut out of my engine harness before I bought it. Thanks for the link, you've been extremely helpful yet again. Hopefully one day I can pay it forward.
Old Mar 25, 2011 | 01:12 AM
  #82
Email crasher's Avatar
Email crasher
ok so I found this image, and Im looking at pin # 30. should we just ground it out???
Old Mar 25, 2011 | 08:20 AM
  #83
49fordpickumup
Unless someone on FTE is a tranny mechanic I can only think of two ways to use the table shown. Take a meter to the salvage yard and test the Neu safety switch or go by a transmission shop and ask the people that overhaul them. I would want the safety switch on the shifter. chuck
Old Mar 25, 2011 | 12:20 PM
  #84
Jeff and Nicolle
http://fordfuelinjection.com/files/EFI_harness4.gif
not sure if it is to be grounded or what? here is a link for wiring diagram.
it shows to be grounded. but I also read about it needing a fused 12 volt source. I don't know? I am still not understanding why you are trying to avoid using the neutral safety switch. seems like if you hooked it up as original then this code 67 would go away. i sent that video link to ya cause it talked about the surging idle issue...now you mentioned a backfiring through the intake and not sure what thats all about.
no problem on the helpin ya, but not sure that i am being any help at this point!
I remember you saying that you harness was cut up, and you didn't know where the neutral safety switch was supposed to connect. is that why you are trying to bypass?
Old Mar 25, 2011 | 12:30 PM
  #85
Jeff and Nicolle
<TABLE style="FONT-SIZE: 80%" align=center bgColor=#e8e8e8 border=1 table><TBODY><TR><TD>Signal Return</TD><TD>Voltage Reference</TD><TD>Ground</TD><TD>+12 Battery Voltage</TD><TD>+12 Run Voltage</TD></TR><TR><TD>EEC 46
Self-Test
MAP or BP
TPS
ACT
ECT
EEC 30 (MT only)</TD><TD>EEC 26
MAP or BP
TPS</TD><TD>EEC relay
Ignition relay
MAF/O2 relay
EEC 20/40/60
EEC 49 (hego)
EEC 30 (AT only)
TFI shielding
HEGO’s
MAF</TD><TD>EEC 1
EEC relay
Fuel Pump relay
Ignition relay
MAF/O2 relay</TD><TD>EEC relay
Fuel Pump relay
Ignition relay
MAF/O2 relay</TD></TR></TBODY></TABLE>
ok look at this ref from FordFuelInjection.com
middle row, middle of list. it says EEC 30 (a/t only) its to be grounded...
this is a link to the whole page
http://www.fordfuelinjection.com/?p=6
Old Mar 25, 2011 | 01:31 PM
  #86
jburroughs12
Yeah, the guy I bought the engine/harness from just cut through the harness going to the dash right at the firewall, so I have no interior harness, therefor no neutral safety switch. I'm not opposed to actually hooking it up, but I'm just trying to get the thing running at this point.
Old Mar 25, 2011 | 07:58 PM
  #87
Jeff and Nicolle
Got ya Joe, I understand. let us know what ya find. I wish you were next door! this is driving me nuts! I wanna know whats goin on with that thing!
Old Mar 25, 2011 | 09:27 PM
  #88
49fordpickumup
Latest goggle find. (1) Fuel min of 35 PSI.
(2) AOD non-elect until 1993
(3) EEC-IV distributor has a electric sensor in/on Dist.
(4) Has a TV cable to adjust.
(5) Having some sensors to fail has a limp home mode.
(6) Needs the computer. Also attaches to the back of the speedometer.
(7) For a transplant it recommended a prior 1988 engine.
(8) Neu safety provides a ground for MAP and also TPS along with a N or P start function. Chuck
Hemmings Motor News: Ford AOD Overdrive Transmission
Old Mar 25, 2011 | 09:46 PM
  #89
Email crasher
BTW Im the guy helping joe out...ie his truck is in my garage lol. ok well Im gonna try hooking that 30 pin to a ground and see what i can get.
Old Mar 25, 2011 | 10:26 PM
  #90
Jeff and Nicolle
hey there email crasher! i kinda figured that but thanks for clarifying!
