issues getting engine swap to run, help.
Old May 17, 2011 | 11:07 PM
  #166
Email crasher's Avatar
Email crasher
We have spark at the plugs, the distributor is turning, timing is what we are thinking. We had to pull the old distributor to put the new one in, and we kept the rotor facing the same way. It doesn't even sputter at all, even with bad timing it should try to start, shouldn't it? We can't get a wrench or ratchet on the crank because it's too close to the radiator.
Old May 17, 2011 | 11:12 PM
  #167
Jeff and Nicolle's Avatar
Jeff and Nicolle
Hey good one on the distributor rotation Sam! i think this was mentioned before but make sure that the dist. is on #1 at the top of the COMPRESSION stroke. not the intake stroke. i have screwed this up more than once! lol
edit: they like to shoot flames up thru the carb if its on the intake stroke! lol and will seem to backfire a little...wake up the nieghbors...
Old May 18, 2011 | 04:08 AM
  #168
sdetweil's Avatar
sdetweil
the old way to turn it is to click the starter, over and over, with the distro cover off.. til you find #1 TDC
Sam
Old May 18, 2011 | 07:48 PM
  #169
49fordpickumup's Avatar
49fordpickumup
Items not seen. Do you see fuel flowing in the carb throat, smell gas. Have you reduced the fuel pressure to 5-7 lbs. What is causing the problem? Elimination process. Fuel/ wiring/timing, etc
Other ways to find TDC, use compression tester, either hand held or the type that screws into the spark plug hole.
I always removed all the plugs as it reduced the resistance the starter has to overcome. Makes the battery last longer during testing. Easier to bump the crank small amounts without over rotation.
I have also used a air hose into the #1 cylinder to confirm compression stroke. I hope this helps. It does get to be frustrating.
chuck
Old May 18, 2011 | 08:48 PM
  #170
carnut122's Avatar
carnut122
Or, just put your thumb over hole #1 while bumping the starter. then check for alignment on the balancer. That will give you #1 on TDC. From there, put the wires in the correct firing order in a counterclockwise direction. It sounds like all you need to do is get the fire to the plugs at the right time. Does it hit on a cylinder even once in awhile?
Old May 19, 2011 | 02:26 PM
  #171
Email crasher
Okay, so we put the engine at TDC on the compression stroke, tried starting it and it hickups sometimes, but won't start, and it looks like the 4th of July on top of my carb with all the flames/backfiring shootin out of it. When we stabbed the distributor, we put the rotor at #1 while the engine was at TDC.
While I'm turning the engine over, Andrew is rotating the distributor to try and find a spot where it will even kind of run, it seems to help a bit, but not enough to get it to run at all. We have the PCV vent on the carb just open to the atmosphere, that shouldn't keep it from starting as that's just to make things more efficient.
I'm using a Mr. Gasket fuel pump that pushed 5-7 PSI. Yet again, we're at a loss here.
Old May 19, 2011 | 03:52 PM
  #172
sdetweil's Avatar
sdetweil
ok, sounds like you are 180 degrees out on the TDC. been there done that exactly..
I ended up taking the valve cover off to verify #1 TDC, front passenger side was actually after the intake valve closed.
Sam
Old May 19, 2011 | 10:18 PM
  #173
49fordpickumup
Are the plug wires and plugs compatible with the new distributor. chuck
  #174
carnut122's Avatar
carnut122
Sam
I agree. Maybe you should put all wires opposite from their current positions to check this out?
Old May 20, 2011 | 08:12 AM
  #175
Jeff and Nicolle
i feel like i am posting for no reason but...like sam and carnut...180 degrees off...i third that..
Old May 20, 2011 | 08:15 AM
  #176
Jeff and Nicolle
refresher!
Old May 20, 2011 | 05:07 PM
  #177
jburroughs12's Avatar
jburroughs12
As a side note, we had it hooked up and it did the same thing, then we rotated it 180, it is currently back firing etc... Hopefully andrew will work on it while I'm out of town and update you guys.
Old May 20, 2011 | 05:55 PM
  #178
carnut122's Avatar
carnut122
Does it fire on any cylinders at all?
Old May 20, 2011 | 11:32 PM
  #179
Mervy49's Avatar
Mervy49
I don't know what alse to add to this. Iv'e been following your delemma for some time. I had a pontiac motor way back in 67 that was acting the exact same way as your describing, we tried everything. Finally, my dad and I took the heads off and there were holes in several of the pistons. Don't ask me how they got there but there they were. After thoughts we had about it ...was, we tried to start it way too many times with the timeing 180 degrees off and burned some of the pistons. I sure hope this isn't what yours did but I thought it might be worth a mention.......mervy.
Old May 21, 2011 | 05:36 AM
  #180
sdetweil's Avatar
sdetweil
a compression tester will help with that..
Sam
