converting from a c6
Old Sep 20, 2004 | 08:05 PM
casey torfin's Avatar
casey torfin
I would like to know if it is possible to change my tranny from a C6 to an automatic overdrive? I have a 1973 f250 with a 390 and its four wheel drive.
If it is possible is it a major project? Thanks for your help casey
Old Sep 20, 2004 | 11:19 PM
85IDIDiesel's Avatar
85IDIDiesel
I am not sure which engine class the 390 is in. But you could go with en E40d which is an overdrive but you would have to wire in the computer. I am sure it could be done but wouldn't be easy. Probably not cheap either. For what it would cost you could probably change it over to a 5spd manual or get a gearvendor or some other overdrive unit to go behind your c6. Used of course as a new one would run you 3 gran.
Old Sep 21, 2004 | 06:12 AM
jowilker's Avatar
jowilker
Casey, Don't think it will happen. Problem is with the bell. Your FE family engine has a round top bell, and most of the ODs have a small block bell. I think there are some adapters but all over $3,000.00 in cost.
John
Old Sep 21, 2004 | 10:31 AM
elemint's Avatar
elemint
I have seen OD units for old c6s for around $1200.
Old Sep 21, 2004 | 01:03 PM
f250rangerexplorer's Avatar
f250rangerexplorer
What do you mean OD unit? what do you mean like a gearvendor? Sorry just kinda confused .
1978 F-250 Ranger Explorer 4x4
351M, C6, Np205, D44, D60LS 4.10
Drive It Like You Stole It!!!
Old Sep 21, 2004 | 01:47 PM
Colo79Ford's Avatar
Colo79Ford
Its an aftermarket OD gear box, that would go behind the tranny, where your transfercase adapter is now. This topic might still be on the first or second page of this forum, i remember posting a link to a good tech article about it not more than a week ago, it should be easy to find, AOD and C6 are in the title, and i believe it says swap in it somewhere too, like i said, page one or two of this forum.
---JOHN
casey88307
Oct 26, 2025 01:40 AM
Tim Casey
1983 - 2012 Ranger & B-Series
Mar 15, 2017 08:36 PM
Casey Friloux
Mar 2, 2017 11:30 PM
USEDCARACE
New Member Introductions
May 31, 2016 03:08 PM
casey meece77
Aug 8, 2013 07:12 AM
