5.4L engine question..need help
Old Apr 18, 2008 | 11:12 PM
sidala's Avatar
sidala
Question 5.4L engine question..need help
i have a 2000 e150 conversion van. when starting the engine get a nice puff of smoke . only happens when starting from cold start and only smokes a second or two. any ideas what may be causing this. other wise runs fine and when starting it after a run in the store or short periods no smoke only seems to happen when sitting for a while
any help would be appreciated
Thanks
Mike
Old Apr 18, 2008 | 11:18 PM
Karl Keicher's Avatar
Karl Keicher
Mike-sounds like you may have some bad valve seals and/or guides. They can be replaced with out too much trouble but will get worse until they are.
