Coil Pack question
Old Apr 18, 2008 | 09:04 AM
Schuby's Avatar
Schuby
Coil Pack question
I have been having a jerk/hesitation/ misifire on my 2000 4.6
It has 110,000. I just changed the plugs in it. Plugs have never been changed in it until I did it this week. My question: Is there any visual cues if a coil pack or COP is bad? Some I pulled off had cracks at the bottom of the boot ( normal rot ), not all the way through but mainly form the inside going out. Are there any visual cues for bad spark plugs since that could be the problem also? Some plugs had some rust around the top porcelin
Old Apr 18, 2008 | 10:33 AM
jozeeparrish's Avatar
jozeeparrish
Have you changed the plug wires? I had a problem just like that with my truck, and the parts strore ran a computer on it with a code of number 3 cyl missfire. I changed the wires and the problem quit. Something about the plug arcing to the head..Hopefull this will help you..
Old Apr 18, 2008 | 12:44 PM
Schuby's Avatar
Schuby
I have coil packs ( Coil On PLugs ) not wires, but thanks for the help..
Old Apr 18, 2008 | 01:31 PM
galaxie641's Avatar
galaxie641
None that I can think of but you can replace the COP boots, it is as close to replacing the wires as you can get and it should be done every other plug change for good maintenance.
Old Apr 18, 2008 | 04:23 PM
Schuby's Avatar
Schuby
where can I get the boots from ( Napa/Autozone)?
Old Apr 18, 2008 | 07:10 PM
galaxie641's Avatar
galaxie641
Yep, anywhere get the cheapest there isn't a difference in them.
Old Apr 20, 2008 | 01:58 PM
ben8892002's Avatar
ben8892002
i had a similar problem with my 5.4 2 boots were cracked from dryrot. letting moisture seep in . changed all 8 boots and problem solved.
Old Apr 22, 2008 | 02:23 AM
LxMan1's Avatar
LxMan1
Make sure to use dielectric grease on the boots to seal them to the plugs.
Scan the computer or misfire codes. It will tell you which cylinder is missing.
Eaulive
Modular V8 (4.6L, 5.4L)
Apr 17, 2010 10:46 AM
Andy's '79
17
Nov 22, 2009 11:55 PM
gottashiftgears
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 27, 2006 10:53 PM
lesmore49
Bronco II
May 16, 2006 08:52 PM
2zuks
Apr 18, 2004 03:57 PM
