Power Steering Issue
Old Jan 10, 2007 | 03:02 PM
Alaska7.3's Avatar
Alaska7.3
Question Power Steering Issue
My PS is not working very well at all when I am stationary. It seems to get better after 10 minutes of driving. Any suggestions and or projections as to how much it would cost if a replacement is needed.
Thanks,
Old Jan 10, 2007 | 03:05 PM
never2big's Avatar
never2big
Have you checked the fluid? Mine started making a whining noise last year and it was low....not sure why cause I have never had a leak or anything. Do you have stock tires?
Old Jan 10, 2007 | 03:20 PM
Alaska7.3's Avatar
Alaska7.3
Stock tires for now (installing 315/70s tomorrow) and I added some fluid as a result of this issue but not any better.
Old Jan 10, 2007 | 03:27 PM
never2big's Avatar
never2big
Well does it do this in the summer too? I see you live in Alaska and was just asking cause of temp diff.
Old Jan 10, 2007 | 03:54 PM
bdrummonds's Avatar
bdrummonds
It will be worse with the 315's, the contact patch of the 315's are roughly twice the size of the contact patch of say a 265/75/16, thus making that much more resistant friction that the pump will have to turn.
How are your Brakes?
since the P/S pump also pressurizes the hydroboost for the brakes, check all fittings and hoses off the P/S pump to make sure no leaky or no crimps.
If all of the above is good then you might want to flush your P/S system and add some conditioner as well as replace the fluid.
Just my .02
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
