Dim Headlights
Old Jan 9, 2007 | 10:25 PM
robjs111's Avatar
robjs111
Dim Headlights
Have A 2001 F350 Diesel And The Headlights At Idle Are Very Weak. What Is Wrong??
Old Jan 9, 2007 | 10:31 PM
Bdox's Avatar
Bdox
Maybe nothing. Check the voltage at the headlamp plug and compare it to the battery voltage at the same rpm. If the voltage at the plug is lower by more than .1v, there may be a poor connection.
If the voltage is the same but below 12.8 at idle, check the alternator output.
Is your idle rpm lower than normal?
Old Jan 9, 2007 | 10:32 PM
05f250fx4's Avatar
05f250fx4
yea mine does this too but then it get bright/normal after a few minutes of driving. its bright on a warm start, but cold start, the headlights will be dim for a few minutes. is this your problem too?
Old Jan 9, 2007 | 10:34 PM
robjs111's Avatar
robjs111
Weak Headlights
I Will Check Voltage. Also F350 Has Twin Alternator From Ford. Rob.
Old Jan 9, 2007 | 10:48 PM
John311t's Avatar
John311t
The reason why your headlight may be dim on start up is the GPs. IIRC they stay on after the light is on and even after the motor is started, they draw 200 amps and that will cause things to dim.
Old Jan 9, 2007 | 11:05 PM
05f250fx4's Avatar
05f250fx4
i dont remember that happening before though. also, my starts seem to be a little longer than i remember. a couple months ago, i had replaced the starter. when i started it up, it was so quick to start it felt like the engine was already warm. then it gradually got slower. then i had to replace the alternator. same quick start up results, same gradual loss. now it turns take about seconds to start where as before it took about 1 second or less, like a new truck.
quincyj34
Nov 10, 2015 03:58 PM
cliffhanger228
Sep 2, 2015 04:59 AM
CPL_Guimonster
Jan 8, 2015 08:19 AM
mckspade
1997 - 2003 F150
Nov 14, 2014 09:04 AM
kountzecobra
17
Apr 5, 2014 06:06 AM
