what is the best mods for the money
looking at getting chip/programer/but dont no witch one is going to give the best for the money.and looking at getting gauges and need to no the best place and the ones im going to need/and new down pipe where to get that also thanks.2001 psd cc long box 4+4,straight pipe
Isspro gauges, pyro boost tranny at the least. There are lots of tuners out there. Chips are about the best for these trucks. Check with Jeremy at LIPD www.longislandperformancediesel.com Or ... nevermind...
I agree boost, tranny, & pre-turbo pyro gauges. Then I would say call Jody at DP TUNER. But then of course, would look into a bigger exhaust and an Intake. You can def. save some green by going with the Napa 6637 filter. I know the chip and exhaust may not be that cheap but the DP Tuner will make her scream.
i talked to jody and yes i will probley get the chip but i pull a bob cat and back hoe so ill have to get the switch on the fly one or 2 or 3 stage,and is the 6637 filter a drop in,i have ram air and would hat to loose it,and what is the best shock to run on my truck and the best spot to get it?
caleb90
07-22-2009 08:02 PM
