Help with water separator 2005
Old Sep 24, 2012 | 07:51 PM
toddrn's Avatar
toddrn
Hi all. I have a 2005 ford f350 6.0. I have a problem with the water separator that I can't figure out. The truck runs great but when the separator needs to be drained the steering wheel will act funny. If I don't drain it the truck will stall.
After I drain the separator the truck will start right up. I have to drain the separator at least once a week, sometimes twice a day. I have changed the fuel filters many times using the ford filters. I replaced the hfcm module cleaned out the junk inside and replaced. The old one had the fuel heater in it. The new one does not. When I drain the separator it looks like clean diesel coming out. It just seems funny to me that the steering wheel would feel funny when the separator needs to be drained. Not sure if there is enough pressure, Any help would be greatly appreciated. Thanks in advance. Todd
Old Sep 24, 2012 | 09:32 PM
BLADE35's Avatar
BLADE35
Never Heard this one Before
As far as I know the water separater has Nothing to do with steering
Have you checked Power steering Fluid and all the Hydro Boost system
Might be a Good Idea to FLUSH the Power steering Fluid and Hydro Boost system with Mercon or some use the Proper Mobil 1 synthetic
let us know if you want to try the PS Flush
Does the WIF Light come on???
or just the steering act Funney???/
Old Sep 24, 2012 | 09:51 PM
toddrn's Avatar
toddrn
the wif comes on sometimes not most of the times. I am wondering if the fuel pressure is low so the truck starts to stall or have low power and that is why the steering would be funny. Thanks Todd
Old Sep 24, 2012 | 10:01 PM
VQT's Avatar
VQT
Sound like you F350 is a diabetic has to take a leak more often than the other
Old Sep 24, 2012 | 10:03 PM
BLADE35's Avatar
BLADE35
That what I thought too Kinda
Im thinking the WIF light comes on cuz the truck is on the verge of stalling this is kinda common
I dont think its from Low Fuel Press but wouldnt hurt to check the fuel press
theres something else going on and the stall and WIF Light is just the side affect IMO
Have you scanned for DTC????
Any Gauges???
Old Sep 24, 2012 | 10:09 PM
VQT's Avatar
VQT
Benny,
What's a "DTC"?
Thanks
Old Sep 24, 2012 | 10:15 PM
Yahiko's Avatar
Yahiko
The engine in a stall will not pump as much fluid to the power steering and
that may be what you feel. I would check the fuel you drain in a clear glass
container look for cloudiness and then let it sit for about 1 Hr and see if
it separates into layers. If you find some thing I would think about
changing the place where you get the fuel. If you don't always get fuel at the
same place you may have water getting into your tank by way of the vent
or the cap.
Sean
Old Sep 24, 2012 | 10:16 PM
BLADE35's Avatar
BLADE35
DTC= Diagnostic Trouble Code
Old Sep 25, 2012 | 01:15 AM
VQT's Avatar
VQT
Thanks Benny
don-ohio
Aerostar
Mar 28, 2017 10:13 PM
cdunn
1983 - 2012 Ranger & B-Series
Nov 22, 2004 07:43 PM
greasymonkey
19
Mar 2, 2004 12:38 PM
manta523
Aerostar
Nov 8, 2003 10:35 PM
390fe
Aerostar
Jan 29, 2003 01:49 PM
