my truck wont run it turns iver but wont run..got codes just now for injector #2,3,4,5,6,7, circuit low..dont know what that means and also got p2617 and p2614 for crankshaft position signal output circuit/open...and also po401 for exhaust gas recir flow which i think is because i deleted my egr...ive changed he ficm so its not the problem..im lost
Clear the codes and rescan to see what comes up. Yes, your going to get a "low flow" on the EGR system if you've deleted or blocked the cooler. Depending on year model, you may also get a CEL (check engine light). The '03 & '04 don't throw the light; '05-'07 will without a custom tune to change the strategy of the engine.
By the way, you don't need to start three different threads for the same problem.
my truck was built in 04/04 and i think the icp sensor is on the valve cover..i dont think its behind the turbo.. theres a plug on the valve cover with 3 wires and has a silver nut looking thing on the bottom..can somebody tell me if thats it
Agreed ^^^^^
Best to keep it all in the same thread
that way we can see what you have what you tried
and where your at
All these diffrent threads is going to be very confussing
i just put the new ficm on friday and its good..it never acted up one time then all of a sudden shut down..whats the pcm...im looking it up now somebody told me it could be that...
If the FICM is that New or been installed that recent have you checked all the Plugs???
Still have the ground wire on the intake stud????
So let us get this straight you installed the new FICM Friday 2 days ago and truck ran with NO Sign of problem then all the sudden Died or stalled Right
So if it died or stalled while running then theres the reason for the CMP/CKP DTC and those probably mean nothing
Did you clear the DTC after the new FICM was installed??????
Is that how it went down???
Must try to separate the Old Codes from the New ones to see WTF
no it shut down 2 mondays ago going hunting so i got it towed back to the house so i thought maybe bad fuel or water so i drained the tank and lines and bought new filters and still nothing so i ordered a new ficm and put it on on friday and still wont crank..turns over fine no crank at all wont even try too....ficm is reading 48v
