most the time i send it to both or all three of u guys to get mutiable input on the subject like when i asked u guys about weilding the rear and taking out a axle shaft on one side for the street but dan hit the nail on the head i stuck with two trany choicse the c6 or e40d tom had a zf5 behind his idi in his 88 but swaped it out for a c6 i bet he did his swap caue of simaler resions
yea i was thought about that but how would i shift squeaze the clute and stear all at the same time ? i was thinking about a buttom on the steering wheel
squeeze the clutch handle, change gears, release clutch.
but this will only work with a short throw shifter.
if you have a supertrucker shifter that is 2 inches from the roof, it will be a little tough.
let me dumb this down for joe
you mount the hand clutch on the shifter, looks similar to a brake lever on a pedal bike. grab shifter pistol grip style, squeeze clutch in, shift, and then release lever
Your hand will never be strong enough to use a hand clutch without a electric/hydraulic or other helping aid.
I was just thinking the same thing. But imagine having the lever operate a rheostat, controlling a little motor that operates the throw-out lever. Set it up so it disengages at full speed and engages in sync with the hand lever.
