Offroad & 4x4
Rockwell Build Thread
Old Apr 18, 2011 | 05:41 PM
  #526
alpha/omega's Avatar
alpha/omega
Originally Posted by Kirbys73F100
Can anyone with real 460 knowledge recommend a decent cam? I don't want to up the stall.
Take a look at the Comp X4262h. I really liked this cam in my first 460. You will need the 926-16 or 924-16 springs (cant remember off hand) and I upgraded the retainers and locks to Comp 7* units.
It worked well with a mildly ported set of D3s, Stealth intake, Holley 750 vac sec and 1 3/4 primary headers and shouldve made close to 400hp.
Old Apr 18, 2011 | 06:54 PM
  #527
Kirbys73F100's Avatar
Kirbys73F100
This one?
COMP Cams 34-235-4 - COMP Cams Xtreme 4x4 Camshafts - Overview - SummitRacing.com
Old Apr 18, 2011 | 08:21 PM
  #528
alpha/omega
yes
<fiiiiiiiiiill>
Old Apr 18, 2011 | 08:38 PM
  #529
fatdan460's Avatar
fatdan460
marriage has already made him tame. on 2nd thought i have no worries of getting any nut pics tomorrow. he'd have to ask to borrow them back from lauren's purse first :flipoff:
BWAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!! :SUPERULTRAMEGATRUF:
Old Apr 18, 2011 | 08:43 PM
  #530
alpha/omega
her meat purse.
Its not hard going bawls deep when youve only got 2 1/2".
Old Apr 18, 2011 | 08:46 PM
  #531
Kirbys73F100
What are you talking about?
Old Apr 18, 2011 | 08:48 PM
  #532
kjett's Avatar
kjett
her meat purse.
He's saying it's all new after the first couple of inches
Old Apr 18, 2011 | 09:12 PM
  #533
fatdan460's Avatar
fatdan460
there is more than one thread on fte kirby. sometimes one thread might carry over into another. just sayin'.
Old Apr 18, 2011 | 10:12 PM
  #534
Kirbys73F100
From what I know and have read on cam choices for my application I want:
Dual pattern (more lift on exhaust to offset poor head flow)
Big lift (.500-.530)
Low duration
More lobe separation (between 112-114) which is less overlap
All of these, in theory, improve low end torque. That being said, I have narrowed down my choices to 3.
1) Alpha's rec, 1,400-5,600:
2) A little less lift on intake, same on exhaust, less duration and more lobe separation, Idle-5,000 rpm range:
Lunati 316A1LUN - Lunati Hydraulic Flat Tappet Camshafts - Overview - SummitRacing.com
3) A little less lift on intake, a little more on exhaust, less duration and more lobe separation, 1,000-5,000.
Not exactly sure how .503 intake/.535 exhaust would behave but this one was worth looking at:
Lunati 61600 - Lunati Voodoo Camshafts - Overview - SummitRacing.com
Alpha's recommendation seems dead on but the 1st lunati cam I listed has some interesting numbers too. Any input?
Old Apr 19, 2011 | 01:27 AM
  #535
hav24wheel's Avatar
hav24wheel
Stick with a RPM range you will use, match that to your cam/intake/carb and exhaust.
Just go with the one Kris said, n it should work for ya.
Old Apr 19, 2011 | 06:36 AM
  #536
kjett's Avatar
kjett
While I like the x-4x4 cams from comp, I'm a little more partial to the xtreme marine line. Paul has my old XM-274 cam in his motor now. It works very well in a basically stock motor with soime porting done to the heads, a stealth intake, 850dp carb and headers. Very streetable with a little lope but gives bobs of torque right off idle. The downside is it's done by 5500 rpm. So if you live in the lower rpms, that line may be a better choice. Think of it this way, big tired/geared trucks with small motors are like boats with 50hp motors. You need instant torque right off the bat to get them up and moving.
Old Jun 14, 2011 | 07:00 PM
  #537
Kirbys73F100
Professional pictures from the mud bog.
... Beginning to hate my Edelbrock carb. Anyone have experience with the Holley Off-Road Truck Avenger carb?
Stupid Jeep was open diff and had to use both of us...
Old Jun 14, 2011 | 08:12 PM
  #538
alpha/omega
Quickfuel! Its the only carb Ill run.
950 mechanical
750 mechanical
Give Joe a call for prices. He was $50 cheaper than Lem, Jegs and Summit last time I priced them.
Joe's Race Parts
EDIT:
wtf is up with you and your buddies butt*****ing each others tires in EVERY pic I see of your truck?
Old Jun 14, 2011 | 08:24 PM
  #539
Kirbys73F100
What does this carb have to help it with angles and getting jarred?
Also, if I read that right, that's a SIX hundred dollar carburetor.
Old Jun 14, 2011 | 08:38 PM
  #540
alpha/omega
Loop a piece of 5/16 fuel line with a little v-notch in it between the two vents. The b-itch will go almost verticle
Its basically a Holley with EVERY bell and whistle you can have plus billet everything. Its a great carb and well worth the money. I think you will find its similarly priced to a similar size/type Holley except without the features and bling. QFT also sells vac secondary and elec choke carbs
see
Holley 0-80529-1 - Holley Model 4150 HP Carburetors - Overview - SummitRacing.com
Quick Fuel Q-750 - Quick Fuel Q-Series Carburetors - Overview - SummitRacing.com
