oh, i just thought it was strange to find a truck s similar. just joking about tryin to fool anyone. my truck could just as easily do the same. not much envy there.
First give away was your has doors that one doesn't..... then that one did have the 53" emblem... o and he had a Hydraulic ram for steering on the front axle... yours doesn't...
thx for pointing out those differences, i couldnt have done it without ya!
Just finished my buddies front 4 link today,
1987 F150, efi 302, T18, NP208, 4-linked D44 with drive flanges 4.10 front with 6" lift Deaver coils, 4-linked D60 FF welded 4.10 rear with 2wd jeep Cherokee coils. I gave him the axles out of my '79 250. Tires are 46x16.1 ags on 16x16 re-drilled tractor rims. Pictures, then video to follow. Its obviously not done yet.
We built our own links with Johnny Joints and leaf spring bushings.
Rear almost complete the night before the Durhamtown Plantation trip
At DP
Rear view
Front clearance test
Then we bet a case on follow the leader. There was no winner.
******** width="480" height="385">
Just got this far today. Still need to buy LED tail lights, fog lights, add a couple gussets and build bumpers. We recessed 3 tool boxes and a 22 gallon fuel cell. Also ended up trimming 8" off the frame. Hope you idiots are enjoying the cold up there! Leaves on the trees and 80 degrees here this weekend.
so do you plan to bring a ladder with you to the gas station every time you need a fill up???? seein' as the filler hole is 6 ft in the air and in the middle of the bed.......
nah, im gonna stand on the ground and shoot it in the hole from there........
