Offroad & 4x4
Rockwell Build Thread
Old Oct 4, 2010 | 01:44 PM
  #256
fatdan460's Avatar
fatdan460
Originally Posted by quadzjr
Preferably with pictures....
Originally Posted by 77mud
Pics are always a plus
of the progress, or him getting hit with a tree? i'd be happy with both, but i'll accept a progress report
i just thought that i would add that i am curious to see this get finished no matter how much bs kirby gets from everyone, myself included.
Old Oct 4, 2010 | 02:10 PM
  #257
kjett's Avatar
kjett
^^^ suck up!
Old Oct 4, 2010 | 02:17 PM
  #258
fatdan460's Avatar
fatdan460
Originally Posted by kjett
^^^ suck up!
you can't see him go down in a ball of flames if he can't drive this truck straight to hell, now can you?
so he needs to finish it first
Old Oct 4, 2010 | 03:21 PM
  #259
77mud's Avatar
77mud
I was talking bout Getting hit with the tree personally, but progress pics would be a bonus... after the tree pics of course
Old Oct 5, 2010 | 09:55 PM
  #260
Kirbys73F100's Avatar
Kirbys73F100
Originally Posted by captain p4
So where are the updates Kirbers?
Wow.. 5 pages of jack **** jiberish. I wondered how long it would take ya'll to tire of bashing someone that doesn't have time to waste arguing with you. I've been busy doing fun stuff so progress has been slow. I've remade the gussets for the swing shackle mounts and installed the bushings. They look MUCH better than the first set. Also welded in a cross member between the spring hangers. I will also gusset these in the front to rear axis. The springs are in but I'm having clearance issues with the pinion brake rotor. Until I decide on what to do about that, I'll have to hold off on welding the perches on and hanging the axle. Spring plates and u bolts are already made. Should have the axle under the truck tomorrow so I can measure for a drive shaft and have it made.
FYI: In order to keep the trans case output in line with the rockwell yoke (and keep the tires spinning the right direction) I'm going to swap the knuckles so the drag link and hydro steer cylinder stay behind the axle.
Old Oct 5, 2010 | 10:12 PM
  #261
Kirbys73F100
Found my girl's first tow truck. Goin' to look at it this weekend. I suspect pickup coil or ignition module. It's gonna be difficult not to rob the axles out of it to put in her mud truck. I'm gonna take a module with me to see if I can hear it run.
1997 ford F-350
Old Oct 5, 2010 | 10:23 PM
  #262
captain p4's Avatar
captain p4
No time to argue with us, yet you keep coming back
Old Oct 5, 2010 | 10:26 PM
  #263
Kirbys73F100
There are some who are interested in my build and there will be more. "Build it and they will come." I just wanted the children to settle their silly differences before I tried to post something serious.
Old Oct 6, 2010 | 12:41 AM
  #264
Prozon's Avatar
Prozon
Just post up progress. If you don't they will run out of things to say haha.
But it would be nice to read something on FTE that isn't bashing at one person or another. I just want to see some crazy *** fabrication.
Old Oct 6, 2010 | 12:43 AM
  #265
Kirbys73F100
I'll post up some pictures when I have something worth bashing.
Old Oct 6, 2010 | 01:04 AM
  #266
Prozon's Avatar
Prozon
Bashing requires no pictures. Haha.
Old Oct 6, 2010 | 06:37 AM
  #267
quadzjr's Avatar
quadzjr
just another Rockwell looser
thats where they are on the duece....
Old Oct 6, 2010 | 06:58 AM
  #268
TheTinian's Avatar
TheTinian
Swap knuckles? You know can rotate the chunk to make it either way. Atleast you can with the 5 tons, I would only imagine the 2.5's are the same....
Old Oct 6, 2010 | 07:14 AM
  #269
quadzjr's Avatar
quadzjr
swapping the knuckles is a lot easier then rotating the 1,835,934 lb chunk and re-sealing it.
especially since he prob. has to rebuild the axles anyway.
Old Oct 6, 2010 | 09:59 AM
  #270
Kirbys73F100
With the drag link in the rear, the chunk on the axle I have is oriented toward the short side axle tube making it passenger side drop.
With the drag link in the front, the chunk on the axle I have is oriented as far to the driver's side as it can be configured. This is where it HAS to be. So in order to keep the drag link in the rear, I have to swap the knuckles.
Rotating the chunk is not a possibility because the driveshaft will hit the transmission pan.
