November Chat Thread
Old Nov 11, 2009 | 10:10 PM
  #151
ctubutis's Avatar
ctubutis
Originally Posted by TheKirbyMan
Oh and btw Ctubutis, do you know how to set things up where a computer running Windows and Linux will use Ntldr instead of GRUB?
I've never done this; I rarely make multiboot systems and, when I do, I've used
Lilo , GRUB and a commercial software product named System Commander.
IIRC to use ntldr, you need to save a copy of the Linux boot sector into a file
(which means you need a hard disk with it installed on) and configure ntldr to
use it. I don't know if ntldr writes that out to the hard drive and then boots
from the disk normally or if it does something else. Regardless, it sounded like
too much work for this boy.
Why do you want to use ntldr? I'm sure google would help ya.
Old Nov 11, 2009 | 10:15 PM
  #152
greyghost85's Avatar
greyghost85
well, you guyz convinced me to stay away from fram
Old Nov 11, 2009 | 10:23 PM
  #153
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Jmeyer1990
Ok, I am hoping to get the oil changed this week, I can't bring myself to get the Motorcraft filter, so should I go with K&N or (please say no) Fram?
DO NOT USE K&N filters!
I put one on my V10 and it had an anti drain back valve that was broken inside of it.
It ran the truck with no oil.
So then I try one on my 460, same thing.
Old Nov 11, 2009 | 10:26 PM
  #154
bill11012's Avatar
bill11012
ctubutis , do you work on computers as a hobby or as a living?
You sound like you really know your stuff ( or you are making it up as you go, I don't speak computer and cant tell the difference!) .
Old Nov 11, 2009 | 10:28 PM
  #155
ctubutis's Avatar
ctubutis
bill11012 (Grant?) I'll try and respond tomorrow, ok? It's bedtime now.
The short answer is: both.
Old Nov 11, 2009 | 10:30 PM
  #156
bill11012's Avatar
bill11012
yes, grant is my real name.
I was guessing you would say both.
Old Nov 11, 2009 | 10:49 PM
  #157
greyghost85
grant, his name is chris
  #158
greyghost85
i am going to hit the sheets, as well
Old Nov 11, 2009 | 10:55 PM
  #159
bill11012's Avatar
bill11012
ok, cool.
I missed that.
You make it easy with it in your sig Darrell.
Old Nov 11, 2009 | 11:03 PM
  #160
greyghost85
you can do that too....or anyone...if an old fart like me can learn this new fangled stuff....lol
Old Nov 11, 2009 | 11:05 PM
  #161
greyghost85
well, goodnite, central texas
Old Nov 12, 2009 | 12:26 AM
  #162
TheKirbyMan's Avatar
TheKirbyMan
Nite
Now that I think back, I think the way I got it to use ntldr last time was because I used the Wubi installer and it auto-configured all that.
I want to use it because it seems a little faster than GRUB. At first I noticed a bit of hesitation when GRUB started loading. But it seems to have gone away for the most part. I might just dig around and find out how to customize GRUB. Maybe add some color, reorder the OS selections list, stuff like that. I did it awhile back, so I know it can be done.
Grant, I've used Fram, Wix and Motorcraft....I get better oil pressure with Wix and Motorcraft, but pressure is lower with Fram. I was told that's because it filters better. I do eventually want to get a K&N filter, but I may put together a custom airbox setup in place of the factory breather, if I can find the right parts.
Just an idea. :P
Old Nov 12, 2009 | 12:34 AM
  #163
bill11012's Avatar
bill11012
K&N makes great air filters, but the oil filters will kill your motor very fast.
Frams filters do not flow as much oil or filter as well.
Wix and FoMoCo are all I run for oil filters.
I have never found a brand of air filter that was bad, but the fram air hog is good and
the K&N is the best.
I put a K&N air filter in and I could tell the difference.
These are things I have learned through trial and error.
Old Nov 12, 2009 | 12:37 AM
  #164
Jmeyer1990's Avatar
Jmeyer1990
AMD Athalon Computer 3200+
I couldn't Resist posting this.
512KB of ram? HAHA!!! I love when people make stupid mistakes like that.
Old Nov 12, 2009 | 12:47 AM
  #165
bill11012's Avatar
bill11012
512KB
I bet that loads fast :P
I am going to bed.
