Adrenaline
Old Apr 18, 2009 | 03:30 PM
  #181
rebelchevy02's Avatar
rebelchevy02
Originally Posted by 89BlackBeauty
I have ordered the Adrenaline pump and can't wait to get it. Robin, I have ICP spikes when I let off at WOT. I will try to run the graphs for you to post, but consistently, ICP drops to around 1800 psi, then I let off and it goes up to 2500 sometimes over 2800.
IMO the fast let off, depends on tuning, and how fast your IPR functions. With the adrenaline I have noticed being able to hold 2400 psi in my highest setting, held to the floor. It doesnt matter how it reacts when your off the throttle, or letting off. What matters is whats capable when your heavy on the throttle, in a high setting.
Old Apr 18, 2009 | 04:39 PM
  #182
Macamon's Avatar
Macamon
A little off topic... What is it when you let off the gas and it sounds like the engine quits running... Then as you slow down it sputters back to life. I never experience the engine cutting out under power, but only as it rolls or goes down a hill.
Old Apr 19, 2009 | 12:43 AM
  #183
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
When you take your foot completely off the throttle the computer shuts the injectors off until you get down to 1200 RPM or you put your foot back in it.
Old Apr 19, 2009 | 01:01 AM
  #184
PaysonPSD's Avatar
PaysonPSD
Originally Posted by westpsd
Robin, I have done many passes on my original stock 15* pump and never saw that spike. I would have freaked out. Like you said, it can't be good for the rest of the stock system. I converted to a stock 17* pump several years ago and I can hold 2800 PSI @ 45% DC on a 120 tune, but I still have the original single shots from the early 99.
Jim
No spikes. Might be that my IPR would not close down quickly enough. I got a rebuilt IPR with the Adrenaline. For another 50 bucks I thought why not.
I would like to know if your ICP spikes after the Adrenaline install. Did you order it wth rebuilt IPR or not?
Old Apr 19, 2009 | 12:55 PM
  #185
MADVAN's Avatar
MADVAN
Robin
I would like to see your UOA's when you get it done.
Are you dino or syn? What weight?
Thanks Bill
Old Apr 19, 2009 | 01:06 PM
  #186
PaysonPSD's Avatar
PaysonPSD
Originally Posted by MADVAN
Robin
Thanks Bill
I will post my next UOA.
Rotella 5w-40 Syn.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
