Adrenaline
Old Mar 28, 2009 | 09:11 PM
  #106
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I hope to know something in here soon. I just got back from town with a pressure tester so I'm going to go pump it up.
Old Mar 28, 2009 | 09:12 PM
  #107
Tenn01PSD350's Avatar
Tenn01PSD350
Where are you at now? What's next?
Dang, never mind.
Old Mar 28, 2009 | 09:13 PM
  #108
cookie88's Avatar
cookie88
FTE Emeritus
Originally Posted by Orezona
Oh my goodness...If I was Bob Riley I'd call that damn parts store and have what ever it is you need delivered to your front bumper!
Funny you should mention that. He called right as I was getting home and made that very offer.
Old Mar 28, 2009 | 09:39 PM
  #109
1996pwrstrk's Avatar
1996pwrstrk
I tell you what gang I've ridden in Scott's truck quite a bit and I can feel a SOTP improvement I mean wow it pulls alot harder . I think it's just what Big Blue needed to get those injectors working .
Old Mar 28, 2009 | 09:43 PM
  #110
F350-6's Avatar
F350-6
So are you downloading the numbers while Scott checks out the pressure Dave? We're starting to think you're toying with us.
Old Mar 28, 2009 | 09:47 PM
  #111
1996pwrstrk
No Scott will give you the #'s I had my whole crew over his house and I had to get them home .I hated leaving Scott to find the leak on his own but I had to.
Old Mar 28, 2009 | 09:54 PM
  #112
tojoski's Avatar
tojoski
He just couldn't stand leaving it til the morning eh? Can't blame him, that would drive me nuts til I found it.
I'll be watching here to see what it turns out to be.
It sure looked like it was coming from the cap though.
  #113
cookie88's Avatar
cookie88
FTE Emeritus
No leaks. Pumped it up to 16 psi and it holds indefinitely.
I then let the pressure off and let it idle on the tester and it only built up about 3-4 psi. Tested the cap I just bought and it would not hold any pressure at all, so I dug the old cap out of the garbage and it will hold only11 PSI.
Old Mar 28, 2009 | 09:59 PM
  #114
F350-6's Avatar
F350-6
Guess you'll need to get a new cap tomorrow Scott. Nothing left to do tonight but share some numbers with us
Old Mar 28, 2009 | 10:06 PM
  #115
Tenn01PSD350
Is that even the right cap? Where'd the POS come from?
Old Mar 28, 2009 | 10:08 PM
  #116
1996pwrstrk
It was the same exact one that he took off we got it at ORielly's.
Old Mar 28, 2009 | 11:40 PM
  #117
mueckster's Avatar
mueckster
We're still waiting.
Old Mar 29, 2009 | 01:43 AM
  #118
cookie88's Avatar
cookie88
FTE Emeritus
Sorry. Got tired, took a shower, DSL went down for a while........
Anyway, what little data I could gather between filling up the radiator looks promising. In any chip setting I'm seeing at minimum a 300psi improvement over stock. I can maintain 2700psi on the 140 setting and it will top 3000psi in the stock setting. Of course I've put a grand total of 9 miles on it tonight......so I haven't even really had a chance to work the air out of the lines yet. Assuming a new cap corrects my coolant issue you can expect firmer numbers tomorrow.
Old Mar 29, 2009 | 02:01 AM
  #119
Stewart_H's Avatar
Stewart_H
Sweet!!!
Looking forward to those solid numbers after you get your coolant issues ironed out.
Stewart
Old Mar 29, 2009 | 02:54 AM
  #120
WA.Ranger's Avatar
WA.Ranger
I was all amped up to order an adrenalin, till something more expensive just went...
