Adrenaline
Old Mar 29, 2009 | 08:20 AM
  #121
1996pwrstrk's Avatar
1996pwrstrk
That 2700 psi in the 140 setting was at 114 mph and still pulling that's when Scott saw the smoke and we found the coolant leak.
Old Mar 29, 2009 | 08:36 AM
  #122
F350-6's Avatar
F350-6
Speaking of smoke, did anyone think to check the stacks? Less black smoke with the new pump?
Old Mar 29, 2009 | 08:39 AM
  #123
mueckster's Avatar
mueckster
Tell us everything!
Old Mar 29, 2009 | 08:44 AM
  #124
1996pwrstrk
I was watching the gauge and it was hard not to look up at that speed. It pulls a lot harder than it used to I mean with the stock pump it would pull ok and to a point then it felt like it would lay down, NOT ANY MORE.
Old Mar 29, 2009 | 10:47 AM
  #125
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Not really less, but there was a change. Prior to the pump it would smoke, then clear, the start smoking hard again at the top of the tach. Now it smokes and doesn't really clear all the way. It's still hazing at full boogie.
To me that says I'm getting much better fuel atomization.....and probably more fuel.
So far today I've refilled the coolant reservoir. I pumped it up to 17 PSI and after half an hour it settled to 16.5 psi. i also went to NAPA and bought yet another cap, which tested to 17 PSI and holds. Then I got the hose out and rinsed off all the coolant remnants, now it's sitting with the hood up waiting for the water to dry before I head out again.
Old Mar 29, 2009 | 10:58 AM
  #126
Kwikkordead's Avatar
Kwikkordead
Congrats on the new pump there Scott.
My truck hits the rev limiter at 83 mph.
Old Mar 29, 2009 | 11:04 AM
  #127
cookie88's Avatar
cookie88
FTE Emeritus
Thanks Dan. I was testing Pressures Friday with the chip removed and was hitting the factory 94 mph limiter.....
I put the chip back in the instant I shut the truck off.
Old Mar 29, 2009 | 11:33 AM
  #128
MADVAN's Avatar
MADVAN
Scott
Glad to see its not a HG!
Could you post your bottom #s with the pump change.
Looking for PW,IPR,ICP at idle hot before and after #'s.
(stock or any tune)
Bill
Old Mar 29, 2009 | 11:46 AM
  #129
tojoski's Avatar
tojoski
Well atleast we know where NOT to buy a degas bottle cap.
Old Mar 29, 2009 | 12:41 PM
  #130
bfife's Avatar
bfife
still plays with trucks
Congrats Scott, I'll bet Bob was glad to hear your #'s after the challanged numbers mine provided. I gotta say I'm jealous of your numbers. I am going to have to find where the rest of my oil is going. Enjoy.. Barney
Old Mar 29, 2009 | 04:29 PM
  #131
Orezona's Avatar
Orezona
Maintaining 2700 with your setup is very good I think. I did three 50 to 90 runs in 80e today. Each time dropped as low as 2100 and threw the P0603
I bet my truck would love the Adrenaline pulling the new 5er to Oregon from Hoosierflatlandville this summer.
Congrats Scott.
Old Mar 29, 2009 | 06:42 PM
  #132
cookie88's Avatar
cookie88
FTE Emeritus
Originally Posted by MADVAN
Scott
(stock or any tune)
Bill
I'm not entirely convinced that it isn't a head gasket since I can't seem to hold the coolant in. I'll be starting a new thread for that.
The bottom end numbers are pretty close to the same. It's maybe 100psi higher at idle now 600psi vs. 500. ICP hangs around 10-12% for both pumps.
I will be interested to find out where your oil is going too.
Congrats Scott.
You'll definitely feel the difference.
Old Mar 29, 2009 | 10:02 PM
  #133
PaysonPSD's Avatar
PaysonPSD
I just got an email from Sheryl and here is the copy and paste.
"Hi Robin Just wanted to let your know that your Adrenaline pump is built, tested and ready to ship. We'll just need you to give Bob a call to go over a few things before we can get it on the way to you. Please call when you have about 20 minutes or so to speak with him".
WAHOO! Bye-Bye 15° HPOP.
Old Mar 29, 2009 | 10:03 PM
  #134
rebelchevy02's Avatar
rebelchevy02
LOL guess whome else just got that same email?
Aside from the Robin part lol
Old Mar 29, 2009 | 10:20 PM
  #135
cookie88's Avatar
cookie88
FTE Emeritus
Are either one of you going to do any data logging, or just slap it on and go? You will really feel the difference coming from a 15° pump.
