Adrenaline
Old Mar 29, 2009 | 10:22 PM
  #136
PaysonPSD's Avatar
PaysonPSD
Originally Posted by rebelchevy02
LOL guess whome else just got that same email?
Aside from the Robin part lol
Right on Mike
Sheryl is working late tonight.
I bet you get your's before me. Arizona is a day further away, at least.
End of Maybe?
Old Mar 29, 2009 | 10:24 PM
  #137
rebelchevy02's Avatar
rebelchevy02
I have AE, so Ill do a before and after, IPR %, and PSI vs rpm.. Anything else I should put in there? Any " I wish I woulda" 's for the folk who havent already "been there" in the hpop swapout? Ive done injectors, etc before.
EDIT, like Ive said before, my hpop on 120r seems to be in the 2100 range. So looking forward to the improvement.
  #138
PaysonPSD's Avatar
PaysonPSD
Originally Posted by cookie88
Are either one of you going to do any data logging, or just slap it on and go? You will really feel the difference coming from a 15° pump.
I did some AE data-logging already but will do it gain right before the install and of course after as well.
Edit: Like Mike
Old Mar 29, 2009 | 10:27 PM
  #139
Chance_Thomas's Avatar
Chance_Thomas
I wonder if Jody has did any live tunning on the pump?
Old Mar 29, 2009 | 10:36 PM
  #140
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Maybe just add injector pulse width to your list.
If I were going to do the job again I would probably go ahead and remove the HPOP reservoir cover. There are a few times...like when you are maneuvering the pump into place while holding the mount bolts in the pump while balancing the gasket on the bolts... that the extra room would have come in handy.
The fuel lines are also easier to remove from the filter bowl if you pop the GPR/IAH bracket loose and move it out of the way.
Old Mar 29, 2009 | 10:48 PM
  #141
rebelchevy02
Sounds like a plan. Ill do some recording the night before, and always have rpm as a reference. When I pull the fuel lines off, I plan to replace them without the check valves inside them anymore also.
Old Mar 29, 2009 | 11:05 PM
  #142
PaysonPSD's Avatar
PaysonPSD
I ordered the HPOP reservoir gasket at the same time I ordered the Adrenaline. It was like 17 dollars and change. I also just ordered o-rings and parker sleeves from Guzzle for my fuel bowl and HPOP fittngs. Yes, sorry to say I still have a fuel bowl.
Good idea Mike on removing the check valve retrictions while doing the HPOP r&r.
I may be getting a hold of one of you if I have trouble data-logging all this.
I also have a PMT1 PCM to go in but will have to wait on that. My DP Tuner will not work with a PMT1 until Jody retunes it. I have an XLE4 PCM right now. At least I will have some numbers to compare the XLE to the PMT to see if there is an improvement.
So much to do and to little time and money to do it.
Old Mar 29, 2009 | 11:12 PM
  #143
rebelchevy02
Our early 99 still has a XLE4 pcm. I cant seem to find rotational velocity in AE for it, but I didnt look too terribly long and hard for it. I had just wanted to see what it was on it one night, after I replaced the injectors with AC's. Im by no means an AE expert, and dont use it too terribly much, but I will be using it more for this test. But Im always glad to try to help. Ill pm ya my number.
Old Mar 29, 2009 | 11:25 PM
  #144
PaysonPSD's Avatar
PaysonPSD
I appreciate the offer Mike. The XLE4 does not do rotational velocity. I found this out after searching in vain for it. I can usually get all the tests running but have a hard time saving them. I will practice a bit this week.
I got your pm and sent you back my cell number.
Old Mar 30, 2009 | 12:15 AM
  #145
cookie88's Avatar
cookie88
FTE Emeritus
Me too. I have no plans on getting rid of it. It flows enough fuel for my needs and is cheap insurance.
Old Mar 30, 2009 | 01:17 AM
  #146
PaysonPSD's Avatar
PaysonPSD
I will probably have mine for awhile because it is too expensive to replace with an aftermarket filter/water separator.
I just read your last post in your HG leak thread. Head lift do to loose head bolts certainly seems plausible. I hope re-torquing them is the fix.
Old Mar 30, 2009 | 06:52 AM
  #147
MADVAN's Avatar
MADVAN
The headbolts could/can stretch.
I checked the napp online and could not pull
the part # up.
We do not use the stuff anymore.
We use exhaust analysis probe in the tank.
Just catch this now before it starts to drink the coolant
if it is a HG. The rod should still be OK.
Bill
Old Mar 30, 2009 | 07:02 AM
  #148
megawatt00's Avatar
megawatt00
I'm probably way off on this but thought to throw it out there any way. Is it possible that the t-stat is sticking partially? Letting just enough coolant to flow so that it dosen't overheat but enough to build a little too much pressure?
Old Mar 30, 2009 | 07:03 AM
  #149
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Highly unlikely, since it's been out only for a few short months at most. Possible, but very unlikely.
Old Mar 30, 2009 | 10:08 AM
  #150
pbr man's Avatar
pbr man
I actually just had this happen on my Dodge Dakota. T-stat stuck part way open, but it blew the seals in the radiator. The tanks started leaking and I ended up changing the radiator. It is possible to pressurize the heads with the T-stat almost all the way closed.
