Adrenaline
Old Mar 28, 2009 | 06:52 AM
  #76
Orezona's Avatar
Orezona
0752 is it on yet?
Old Mar 28, 2009 | 07:38 AM
  #77
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Time to get up Scott. DING DING
Old Mar 28, 2009 | 07:40 AM
  #78
beanhead6D5's Avatar
beanhead6D5
7:40 and counting!
Old Mar 28, 2009 | 07:47 AM
  #79
mueckster's Avatar
mueckster
Inquirying minds want to know. Get'r done!
Old Mar 28, 2009 | 09:34 AM
  #80
bfife's Avatar
bfife
still plays with trucks
Originally Posted by cookie88
Haha....no.
I do have some preliminary numbers to chew on.
I followed the hpop test instructions on swamps website, and a sustained burst from 50 to 100 mph in sixth gear on the 140 setting yields a maximum of roughly 2500psi and it will stabilize around 2250-2300. The duty cycle will spike to 75% and fall off to 55%.
On the stock setting the pressure will peak at 2300 and hold and the duty cycle will not quite reach 50%
So.....if I read this right my stock pump just barely qualifies as "marginal".
Scott, those are solid numbers for a stock pump. I could never get over 2200 spike and a sustained if 1900 with my stocker.
The oil lines come off eaisily. you don't have to have the "tool". the fittings will swivel in the quik coupler so you can just unscrew the fittings at the pump and leave the hose and fitting attached to the truck while you remove the pump.
Barney
Old Mar 28, 2009 | 10:58 AM
  #81
Pocket's Avatar
Pocket
Barney
An even easier way is to take two screwdrivers, push down on the lock, and pop off the oil lines. They come off instantly that way.
Old Mar 28, 2009 | 11:11 AM
  #82
Kwikkordead's Avatar
Kwikkordead
Looking at the picture of the Adreneline pump, there is no flange installed in the pump. You have to use the existing flange anyway so why not just unscrew it from the stocker anyway?
Old Mar 28, 2009 | 11:15 AM
  #83
ron's power stroke's Avatar
ron's power stroke
I un hooked my lines for piece of mind..I wanted to make sure the fitting went on strait in my new pump..they pop off pretty easy once you figure it out....
Old Mar 28, 2009 | 12:13 PM
  #84
Tenn01PSD350's Avatar
Tenn01PSD350
Just popped in on my lunch break to check it out.
Guess I'll find out after shift tonight. Good luck with it Scott. Looks like you'll have some help.
Old Mar 28, 2009 | 12:20 PM
  #85
Chance_Thomas's Avatar
Chance_Thomas
Has Jody did any live tunes on the pump? I'm curious what he thinks of it.
Old Mar 28, 2009 | 01:31 PM
  #86
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The pump is on. Taking a break for lunch then I'll go put the rest of the truck back together.
Old Mar 28, 2009 | 01:34 PM
  #87
Kwikkordead
Woo Hoo!!!!
Old Mar 28, 2009 | 01:36 PM
  #88
beanhead6D5
Sounds good Scott,Were waiting and watching.
Old Mar 28, 2009 | 03:26 PM
  #89
jdecker88's Avatar
jdecker88
Great to hear scott
Old Mar 28, 2009 | 04:09 PM
  #90
cookie88's Avatar
cookie88
FTE Emeritus
Now the truck is done....letting the old girl warm up while I clean up tools and leak check.
Driving impressions to follow.
