Part VI
Old Dec 5, 2009 | 07:02 PM
  #22561
DieselCamper01's Avatar
DieselCamper01
Still does not make it fun though
Old Dec 5, 2009 | 07:55 PM
  #22562
AzBlueWolf's Avatar
AzBlueWolf
Jay, I have prolly done 30 of the 3.1L intakes...but there is a huge difference between the intake and head gaskets!
replace the tstat and gasket, clean and lube the orings on the injectors...a little oil works great...the intake bolts only get tightened to 11 ft lbs and the upper plenum get 18 ft lbs...its not a lot...use caution!
Old Dec 5, 2009 | 08:07 PM
  #22563
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by AzBlueWolf
Lisa has bad azz gas?
lol no...has nothing to do with gas. Just intolerance to certain kinds of foods...anything high in fat content tends to make me pretty sick. The surgery I had was to remove a bad gall bladder that hadn't been working correctly since birth. I just get an upset stomach a lot when I don't eat right or when I get really stressed, is really all it boils down to.
Originally Posted by DieselCamper01
Haha i don't know about Lisa but I do!!
Well, tore apart the intake on the Llumina. Looks like bad gaskets. Not as bad as I had thought. I spoke with Mike (Ford79) for quite a while. He did some research for me and seems that is a pretty common issue on that motor. So now I need to order some parts and do a little routine maintenance while everything is apart.
Thanks Mike!!!!
That's super good news Jay.
Originally Posted by mxracer3276
No not at all. You're fine.... Well to start, i was a catcher for about 12 years so that started things, i am an avid snowboarder, and at one point i was squating close to 700 pounds. The day after my high school graduation i had my first knee surgery which was both knees at once. Then i had my next which was also both knees. Then i had my left one done 4 more times because i was an idiot and cant stop playing sports. Then finally, i screwed the bones up so much in that knee that they just replaced it which will have to be redone in like 10 years
Well I have a brother-in-law who has had both hips replaced (skiing and trapeze) and he tells me that joint replacement technology gets better and better every year....so maybe in 10 years they can accommodate you with one that is much more advanced. Still, going through invasive surgery like that can't be much fun.
Old Dec 5, 2009 | 08:11 PM
  #22564
7.3 Rocket's Avatar
7.3 Rocket
Well to steal Lisa's terms bumpercar season has officially started in CT.
Went to the NAPA warehouse to grab a new float for the snowblower's carb. Well on the way back I saw at least 3 accidents. One in the ditch going my way. One in the ditch going the other way and one spun 180* and into a jersey barrier.
And that darn new float still didn't fix the problem. Grrrr. Snowblower works great so long as you keep it at full throttle and shut the gas off when you shut it off.
And Tom yes the key really is keeping your foot in it. Surprisingly enough that's finesse in these trucks. Not just rookie stuff.
Old Dec 5, 2009 | 10:06 PM
  #22565
deereman4020's Avatar
deereman4020
Hey y'all. I've had one hell of a day today. Went 2-3 on for the day my 2 wins were from pins. the team went 5-0 and took home a trophy from the duel meet tourney we went to.
Old Dec 5, 2009 | 10:08 PM
  #22566
willeo6709's Avatar
willeo6709
Thanks Lisa. Not that there is ever a "good" time but this really is gonna put the pinch on us I think.
If its an overhead cam you'll need to do the timing belt at the same time.....sure its a gasket and not a cracked head? Some aluminum head motors were infamous for cracking the head if they had any issue that ran them low on coolant.....
Old Dec 5, 2009 | 10:15 PM
  #22567
willeo6709's Avatar
willeo6709
the first deer season officially started in Iowa today. Party hunting is legal here ( get your mind out of the gutter guys... it means you can have a group of hunter do drives and all hunt until all licenses are filled). My group this year had 6 people and 8 licenses. We got 6 deer by noon including about a 160 class 10 pointer......I shot 5 of the 6 including the big buck. We did another scouting run and knocked off early. Back out in the morning to finish up.
Old Dec 5, 2009 | 10:35 PM
  #22568
rbaker6336's Avatar
rbaker6336
Sounds a lot like a needle valve problem.Could be trash,a bad needle or incorrectly adjusted
Old Dec 5, 2009 | 11:02 PM
  #22569
7.3 Rocket's Avatar
7.3 Rocket
Were it a bad needle valve would the flow of fuel stop if I had the bowl off and pressed the float up manually?
The old float had a hole in it and filled with gas so it wouldn't lift and shut off the flow of fuel. I don't know what the issue is with this one but I know I can push the float up with my finger and get the fuel flow to stop.
Old Dec 6, 2009 | 05:13 AM
  #22570
AzBlueWolf's Avatar
AzBlueWolf
maybe the float is out of adjustment now... how old is the snowblower...and how much is trouble free worth....check prices on a new carb
morning all...40° brrrr!
Old Dec 6, 2009 | 08:17 AM
  #22571
lowbed dud's Avatar
lowbed dud
morning all , brrrr 7*
Old Dec 6, 2009 | 08:42 AM
  #22572
7.3 Rocket's Avatar
7.3 Rocket
Mark it's an almost new husqvarna. Trust me it wasn't free. It runs and runs strong just pisses gas if I forger to shut the fuel off when I'm done.
Old Dec 6, 2009 | 08:45 AM
  #22573
Smokin''s Avatar
Smokin'
Smokin
Morning everyone.
Wow...congrats. Plenty of venison to go around.
Bout the same here.
Old Dec 6, 2009 | 08:56 AM
  #22574
preppypyro's Avatar
preppypyro
Morning all, minus 16C here they say it feels like minus 25C though. For you F'ers (Fahrenheit' ers )thats 2F, feels like minus 13F.
Old Dec 6, 2009 | 09:32 AM
  #22575
Ford79's Avatar
Ford79
Good morning everyone.
It's currently 2F here, can you please take your cold weather back It was 48F here just 5 days ago.
