Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread,,, Part 2
Old Jul 23, 2012 | 07:28 AM
  #11851
Jigger2020's Avatar
Jigger2020
Good luck with all that Sherm
Old Jul 23, 2012 | 07:48 AM
  #11852
yamagrant's Avatar
yamagrant
Good Monday mornin all.
Old Jul 23, 2012 | 07:49 AM
  #11853
Jigger2020's Avatar
Jigger2020
Howdy Grant, I like yer ''lawn boy''
Old Jul 23, 2012 | 08:03 AM
  #11854
preppypyro's Avatar
preppypyro
Morning everyone!
Morris, excellent advice on how to solve Aarons one minor snag. Really is a pretty simple fix Aaron, dont let it slow ya down!
Sherm, good tools is always a must! Sounds like your like the rest of us though, try to get away with out the proper tool first, then find out ya need to redo it with the tool haha. Been there a few times!
Old Jul 23, 2012 | 11:02 PM
  #11855
Fomoko1's Avatar
Fomoko1
Likely that`s a high maintenance type.....
Old Jul 24, 2012 | 06:48 AM
  #11856
Jigger2020's Avatar
Jigger2020
Good Tuesday morning FTE gang, have a great day.....
thats for sure
Old Jul 24, 2012 | 06:55 AM
  #11857
96sherm's Avatar
96sherm
Morning...Well I got ambitious last night and pulled the car apart again, got the rear end on the bench for the 2nd time. The three things I suspected were wrong are wrong. We had backlash set too tight, it was at 0.005", when spec is between 0.008"-0.015", ideal setting is between 0.012"-0.015". Our pinion depth was too shallow causing the pinion to run on the heel of the ring gear, more shims needed to bring it more to the center of the ring gear. Lastly was the preload on the new pinion bearing. It should only be 16-29 inlbs, I'd say we were closer to 50 inlbs of rotating torque. One needs a "dial" type of torque wrench, a "click" style won't work.
So with all that said and done, I need to get another inner pinion bearing cause I wrecked one pulling it off the pinion with a chisel. I've got new shims, and I know how much I need to move the carrier to get the proper backlash... Perhaps some more ambition tonight and we'll be rolling successfully again...
Old Jul 24, 2012 | 07:03 AM
  #11858
Jigger2020's Avatar
Jigger2020
Yup, sounds like you know what to do now.........good luck
Old Jul 24, 2012 | 07:04 AM
  #11859
96sherm's Avatar
96sherm
yup...just one more tool...lol... I think a person should be able to guage the rolling resistance of the pinion bearing... it should spin by hand with a little effort, not free wheel, but not have to grunt to spin it...
Old Jul 24, 2012 | 07:11 AM
  #11860
Jigger2020's Avatar
Jigger2020
Ya once you break it loose you need about 15 in lbs of resistance
Old Jul 24, 2012 | 07:16 AM
  #11861
96sherm's Avatar
96sherm
sure taking less time this time...If I screw up again, I'll have this thing out and in within an hour...lol
Old Jul 24, 2012 | 07:19 AM
  #11862
Jigger2020's Avatar
Jigger2020
I'm pretty sure you have a plan now.....google what you need to know
Old Jul 24, 2012 | 08:13 AM
  #11863
yamagrant's Avatar
yamagrant
Happy Tuesday mornin' all. Pulled the front sheetmetal off the 56 last night, will clean and paint the frame this weekend. have a good one
Old Jul 24, 2012 | 08:18 AM
  #11864
Jigger2020's Avatar
Jigger2020
Howdy Grant, looks like you better buy extra booze for that job and some band aids too
Old Jul 24, 2012 | 08:30 AM
  #11865
Fomoko1's Avatar
Fomoko1
Good morning guys.
Sounds like your having too much fun Sherm and Grant.
What are you up to these days Gerry?
