Crewcab Only Thread.
Old Oct 3, 2009 | 10:22 AM
  #691
pvillebo's Avatar
pvillebo
That does look good Todd.But from looking at how much of the roof your headliner covers looks like the last guy has screwed that up for me to.I'm not positive,I will have to look again,but I don't think I have enough frame to do the whole roof.I like how you added that extra light to.Where or what did you wire it in at.You can never go wrong with more light.
Old Oct 3, 2009 | 10:57 AM
  #692
pvillebo's Avatar
pvillebo
After looking at it,there is enough there to do the whole roof but one piece is broke and the molding that goes across the middle is only about 2/3 as long as it needs to be.But I will figure something out.
Old Oct 3, 2009 | 11:00 AM
  #693
ranger429's Avatar
ranger429
The light can be wired right to the door jamb switch or the headlight switch.
My center plastic piece is pretty busted up and I've thought about using a piece of 1/2" wide aluminum strip there or nothing. Depends how sturdy the board is once in place.
Old Oct 3, 2009 | 11:28 AM
  #694
pvillebo's Avatar
pvillebo
Ranger,have you posted any more pics of your crew since you posted the ones in July?I want to get my done so bad I can taste it.My problem is I don't have no room or a shop to work on it so I am trying to get everything lined up so when I start on it I won't have everything strung all over the place but for a little while( thats the plan anyway).
Old Oct 3, 2009 | 11:43 AM
  #695
ranger429's Avatar
ranger429
Yes there is a thread in this section on my build. Crewcab restoration or something like that, I'n on a blackberry so I can't get the link.
Old Oct 3, 2009 | 12:55 PM
  #696
ranger429's Avatar
ranger429
Well after making a trip to Lowes and measuring the OE headliner I don't know if I'll be able to find a piece big enough to make it in one piece. Measurements for the OE headliner are 61" by 53 3/4", a little to big for a 4x8 piece.
Old Oct 3, 2009 | 09:34 PM
  #697
Todds79's Avatar
Todds79
ranger429,
I had thought about the aluminum strip also, but the orginal worked back. I had to use some small self tapping screws on the edges where the two pieces meet, just in the curve to hold it up tight. Then I was able to use the original strip. I used one 4x8 sheet--cut the rear out first, then used the end for the front. It was not quite long enough, so I joined some of the scrap to make a piece long enough for the front. The patch was a section about 5" wide glued to the topside. From the bottom you can't tell it, and after covering, you never knew it was glued together.
The dome light was easy, just tapped into the wire going to the rear light. I also ran a fused wire that is hot all the time for the map lights in the same fixture.
Old Oct 3, 2009 | 09:37 PM
  #698
ranger429's Avatar
ranger429
My original trim piece in the center is pretty cracked up. It would work if I had to do 2 seperate headliner pieces but I figured one solid piece would be better and then the strip wouldn't be necessary. I don't know if I'll be able to find a piece of board big enough to do it in one piece.
Old Oct 4, 2009 | 11:56 AM
  #699
ChaseTruck754's Avatar
ChaseTruck754
Like all - my center piece is trash too. When I do the aluminum one I plan to bead roll it with an "offset" pattern to give the thing (only like .032 thick) some rigidity. I just left one piece of the aluminum longger than the other and due to the "offset" type bead roll in the thing I can overlap them easily.
I have the aluminum and have had the pattern traced on them (my front headliner was good - back was deteriorating fast) for almost a year now. One of these days I'll get to working on that part of the project again
Old Oct 4, 2009 | 03:19 PM
  #700
crazyredneckanyhow's Avatar
crazyredneckanyhow
Ranger im sure you can get alum. in 5x10 sheets if youd want to go that way. Im not sure what im goin to do.
Old Oct 4, 2009 | 03:39 PM
  #701
ranger429's Avatar
ranger429
That might be another option, it might look pretty good up there as well.
Old Oct 4, 2009 | 03:42 PM
  #702
crazyredneckanyhow
Id bead roll it like steve is sayin. It would look good
Old Oct 5, 2009 | 10:35 AM
  #703
pruitt's Avatar
pruitt
new crew cab owner, picked this one up a couple weeks ago, was building a supercab and decided i want a crew so this is the start now to get it all together. 1979 4x4 44 front 60 rear, 400M c6 205, A/C. setting in the garage for this ride is a 95 12valve cummins and nv4500 and a set of dana 60's from another 79 i have.
Old Oct 5, 2009 | 11:53 AM
  #704
ranger429's Avatar
ranger429
Looks like a great start. I found that formica countertop comes in a 60” wide piece and is only a 1/16” thick. I got a sample piece I'm going to try out
Old Oct 5, 2009 | 12:12 PM
  #705
ChaseTruck754
nice truck Pruitt. I know Dave (crazyredneck..) was looking at that one too. Seems like a good start!
