223 needed
Old Mar 2, 2023 | 06:54 AM
  #166
pintoplumber's Avatar
pintoplumber
For the old, uneducated (like me), what’s 5 lbs of blow?
Old Mar 2, 2023 | 07:48 AM
  #167
DieselDog409's Avatar
DieselDog409
5 pounds of cocaine
Old Mar 2, 2023 | 11:31 AM
  #168
abe's Avatar
abe
I was wondering the same, Dennis, but I acted cool and didn't want to ask. LOL
Old Mar 3, 2023 | 09:46 AM
  #169
hiball3985's Avatar
hiball3985
Unhappy
Originally Posted by mOROTBREATH
The plastic ones work but have a reputation for falling apart with modern ethanol fuels. They'll work for the time being.
Many will be aware of the problems of the adding of Ethanol to our petrol and its ability to 'un-solder' joints in fuel pipes and floats in carburetors (the Ethanol dissolves the lead and tin in the solder). They are out to get us anyway they can...
Old Mar 3, 2023 | 10:26 AM
  #170
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Ethanol has it's issues especially with certain rubber and plastic compounds. However, there is no way ethanol will dissolve or unsolder lead/tin. Generally, solder is used in conjunction with a flux and trace amounts of leftover flux remain on the joints. Fluxes can be soluble in ethanol, thus the appearance of the joint can change after the ethanol reacts with the flux. Perhaps that is the source where this (incorrect) idea stems from, but there exists no form of any chemistry that could dissolve metals present in solder in ethanol. Additionally, ethanol can react with aluminum and form aluminum triethoxide, Al(OC2H5)3 which can make a mess of aluminum body carburators.
And just to be clear, I'm not making any overall claims regarding the [controversial] inclusion of ethanol in gasoline, just facts around the specific chemical reactions debunking this particular myth.
Old Mar 3, 2023 | 02:43 PM
  #171
DieselDog409
any way to convert the current distributor to mechanical advance? as i am making a custom 4 barrel intake to tune the outer cylinders individually and the 2 shared banks of 2 in the middle apart from each other, my design will be one barrel per intake port
Old Mar 3, 2023 | 02:47 PM
  #172
DieselDog409
I know this is not a liked subject for you guys to hear and it is a big project for me to do but i want to at least try as it is going to cost me nothing because i have a carb for it and the metal to make it. The mounting plate is being plasma cut at my school shop from a cad file i made of the intake pattern and 3/8 inch steel plate
Old Mar 3, 2023 | 03:44 PM
  #173
bmoran4's Avatar
bmoran4
The only real way to swap vacuum to mechanical advance would be to swap out the existing distributor for another one, most likely a modified GM one).
Here is a commercial example: https://vintageautogarage.com/ford-1...vance--fd4953/
A thread discussing specifics: https://www.ford-trucks.com/forums/1...a-223-six.html
Old Mar 3, 2023 | 07:50 PM
  #174
DieselDog409
thanks your a big help dude
Old Mar 8, 2023 | 12:45 PM
  #175
DieselDog409
What y blocks share the 223 bellhousing pattern other than a 292 or 312
Old Mar 12, 2023 | 04:54 PM
  #176
ManFordman2's Avatar
ManFordman2
Since the really knowledgeable did not answer, I thought I would take a stab at it: My impression is that all ford truck y blocks share the same bell housing hole pattern. However, I believe that the bell housing for a 223 is not going to bolt up to a y block. Please correct me if I'm wrong.
Last edited by ManFordman2; Mar 12, 2023 at 04:59 PM. Reason: To make a few corrections.
Old Mar 12, 2023 | 06:31 PM
  #177
raytasch's Avatar
raytasch
Believe Nothing
Back in the mid 1970s I replaced a 223 with a Y block in a 1963 P350. Any Y block you would want to install in that truck should fit.
Old Mar 12, 2023 | 08:14 PM
  #178
bigwin56f100's Avatar
bigwin56f100
you are correct.
223 bell will not work with a y block
all 239, 256, 272, 292,312 y blocks will bolt up to a truck y block bell.
Old Mar 12, 2023 | 09:37 PM
  #179
52 USCG Panel's Avatar
52 USCG Panel
I'm sure you are correct about the bell housings being different. I've always thought though that the new overhead valve 215/223 I6 engines were similar in some ways to Y blocks and may in fact share some parts. Am I mistaken in this? Thanks.
Jim
Old Mar 12, 2023 | 09:53 PM
  #180
bigwin56f100
Jim
on the 215-223 the top 2 bell housing bolts are closer together than that of a y block
east way to remember is the 6cyl the bolts are close like the width of the head and the Y block are spread apart at the top
