223 needed
Old Mar 13, 2023 | 07:10 AM
  #181
hiball3985's Avatar
hiball3985
Everyone is correct, the Y block and 223 are different. The only other engine using the 215/223 bell housing bolt pattern is the 262. there are several 223 type bell housings, one for 3 speed trans, one for 4 speed trans and with and without mounting provision for hydraulic clutch.
Old Mar 14, 2023 | 03:59 PM
  #182
DieselDog409's Avatar
DieselDog409
what about the part of the bell that bolts to the trans
Old Mar 14, 2023 | 06:41 PM
  #183
ManFordman2's Avatar
ManFordman2
So, if you were to replace the 223 with a Y block you would need the Y block to 4 spd bell. The 223 bell hole pattern is smaller as is the alignment bore.
Old Mar 14, 2023 | 08:18 PM
  #184
bigwin56f100's Avatar
bigwin56f100
what about it?
transmission doesn't care. That is if we are talking about a transmission that is from this time frame. A 56 f100 y block truck with either a 3 speed or a 4 speed will bolt right up to a 56 223 bell housing.
when I read that it just doesn't make sense
a transmission behind a 223 will bolt up to a y block bell housing no problem
A transmission behind a y block will bolt up to a 223 bell housing
so long as we are talking truck applications meaning truck trans mated to a truck bell housing
car trans and truck bells do not interchange nor do car bells work with truck transmission
Old Mar 14, 2023 | 09:40 PM
  #185
DieselDog409
this is going in a 1950 f5 that has a 223 in it newer than 61 and i found a cheap 292 local to put in it
Old Mar 14, 2023 | 09:42 PM
  #186
DieselDog409
ok i get it now thanks
Old Mar 16, 2023 | 10:36 PM
  #187
48/51F1's Avatar
48/51F1
I've got a 223 Bell housing for a c4 automatic
Duffy351
2004 - 2008 F150
Sep 16, 2014 09:07 PM
abelmoreno
Jul 22, 2008 02:48 PM
bnk190
Modular V8 (4.6L, 5.4L)
Apr 3, 2008 01:38 PM
66beater
Jul 25, 2005 08:17 PM
lwcassady
Bronco II
Mar 31, 2005 08:11 AM
