223 needed
Old Feb 7, 2023 | 08:12 AM
  #136
DieselDog409's Avatar
DieselDog409
i would show you a video of it running but the video is too large to upload
Old Feb 7, 2023 | 08:26 AM
  #137
Harrier's Avatar
Harrier
When I want to post a video, I upload it to YouTube and then post the link.
Old Feb 7, 2023 | 08:30 AM
  #138
DieselDog409
you cant upload to youtube on a schools computer
Old Feb 7, 2023 | 08:31 AM
  #139
DieselDog409
also scroll up as there is a link for mud tires for these trucks also i found a set of the radial rims on a local motorhome in the trees
Old Feb 7, 2023 | 08:32 AM
  #140
DieselDog409
i will have to see if i can buy the motorhome for the "Motor" i need and not bring up the wheels so i can get it cheap
Old Feb 22, 2023 | 01:48 PM
  #141
DieselDog409
does anyone have a x fitting that goes on the back of the master cylinder on these trucks as i think i cracked mine on my drive last week, because when i pulled into my driveway the brake pedal goes to the floor and all the lines are holding pressure as well as the master.
anything helps
Old Feb 22, 2023 | 01:50 PM
  #142
DieselDog409
also i have located two sets of 6 of the dodge motorhome 19.5 rims and have Bought a set of six for $600 total for my truck, so make offers for the three good tires on my truck and all the rims. i have 8 split rims 6 RH-5 and 2 three piece rims
Old Feb 22, 2023 | 01:53 PM
  #143
DieselDog409
one new mud/snow one new coop contry squire, and one 50% cracked up bad lug tire all come on rims and 2 %40 steer tires and 4 bald lug tires
Old Feb 22, 2023 | 01:56 PM
  #144
DieselDog409
i need money for some new tires for the motorhome rims
Old Feb 22, 2023 | 01:58 PM
  #145
DieselDog409
the reason i got the rims off that motorhome so cheap is because the people at the yard know me and gave me a birthday discount of $4,400 for the rims as they knew they were worth a lot of dough
Old Feb 22, 2023 | 01:59 PM
  #146
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Great find on the 19.5 rims! Price seems very reasonable too! Should have both both sets and sold one for profits to fund your project ;-P
For the brake line manifold, do you have the 5 port used with a brake booster, or 3 port used for non-powered brakes? The 5 port is not reproduced. The 3 port is readily available from our specialty parts suppliers:
https://midfifty.com/item.php?INV_ID...ole-feed-block
You can make a 5 port from standard fittings replicating the original schematic below:
If your pedal is not returning and you had a leak, it should be pretty obvious. If no leak is found, it could be that your flexible brake lines have swollen internally and are acting as a check valve and are not returning. Being that yours are at best 15 or so years old, their life is probably up any ways.
Old Feb 22, 2023 | 02:11 PM
  #147
DieselDog409
my rubber lines work fine at 40+ years old and i have no brakes they dont work and i have the non boosted brakes.
Thanks for the links.
Old Feb 22, 2023 | 02:12 PM
  #148
DieselDog409
The yard has one set and some random guy i am tracking down has the other set on his motorhome.
Old Feb 22, 2023 | 02:13 PM
  #149
DieselDog409
but would you want any of my old tires and rims
Old Feb 22, 2023 | 02:19 PM
  #150
bmoran4's Avatar
bmoran4
Did you properly adjust and bleed the Lockheed brake system? They are interestingly different enough from other brake systems as they have the 4 cam adjusters for the shoes.
I appreciate the asks on the rims/tires, but I am set for the moment and shipping/freight does add up.
